Author Topic: other maintenance when fairing off?  (Read 3452 times)
Offline h2smokin
« on: October 09, 2012, 01:28:43 PM »
Curious as to what other maintenance I can get done or is necessary while fairings off? I'm gonna be doing the A&R light setup which means I have to remove some fairing parts. Anything else I can do while they are off the bike? I plan on running my aux. lights I ordered and thought maybe flush the radiator? Anything I'm missing? Thanks
Re: other maintenance when fairing off?
« Reply #1 on: October 09, 2012, 02:46:16 PM »
check header nuts
« Reply #2 on: October 09, 2012, 03:01:37 PM »
Coolant change
Offline Cheesecake
« Reply #3 on: October 09, 2012, 03:20:53 PM »
Clean/replace air filter
2008 C-14
« Reply #4 on: October 09, 2012, 04:35:34 PM »
Change blinker fluid.
Offline h2smokin
« Reply #5 on: October 09, 2012, 04:42:47 PM »
Almost forgot about the blinkers, just have to find the fluid now. I did forget about air filter thought , thanks
« Reply #6 on: October 09, 2012, 04:45:07 PM »
Are you going to use synthetic?
« Reply #7 on: October 09, 2012, 04:56:20 PM »
Offline h2smokin
« Reply #8 on: October 09, 2012, 09:06:32 PM »
synthetic on the blinkers? , NAH,  not much wear and tear on them :D
« Reply #9 on: October 09, 2012, 09:19:23 PM »
Whatever you do, don't swap the blinkers with car blinkers, we'll never hear the end of it 8)
Offline curly
« Reply #10 on: October 10, 2012, 02:24:15 PM »
Check for mice? Sorry MOB, couldn't resist.
'09 in Black.
Offline Dodgedoc
« Reply #11 on: October 10, 2012, 04:22:34 PM »
install nitrogen in the blinkers  it runs cooler
We would not be here now if we did not leave there then
Offline Rocket Therapy
« Reply #12 on: October 11, 2012, 07:03:48 AM »
I thought that was Blinker Ice
« Reply #13 on: October 11, 2012, 11:03:58 AM »
 :rotflmao: :rotflmao: :rotflmao: :thumbs:
« Reply #14 on: October 11, 2012, 03:37:30 PM »
You know, we laugh at that but it's not a bad idea...
« Reply #15 on: October 11, 2012, 03:51:29 PM »
Install sticky traps, if you smell cooked meat then you know it's time to change traps.
