Author Topic: The plastic key holder on the 2010 C-14....how does it work as a transponder?  (Read 2420 times)
Offline ninjawarrior1400
My 2008 got two pocket transponders..sold it....got the 2012 which has only one.  However, this plastic key "card holder"  is allegedly supposed to work as a transponder too?
If so, have not been able to get mine to do anything when placing it against the main ignition switch....
Does this thing do anything other than retain a small key for your trunks?
Please anyone advise me on this item.....
Ninja
Ninjawarrior
Offline Makz58
It will let you start your bike....there is a little triangle shape on one corner of the key holder....hold this on the windshield side of the ignition....on top of the rectangular projection or see page 96 in owners manual.
C-14 2010
Offline RBX QB
Your manual has instructions for how to line up the small card so it works. I don't have it with me... but its as Makz said (tho, there's a diagram in the manual, if memory serves).
2011 Concours 14 ABS
Ok!  It worked just as you explained...thanks...finally after owning the bike two years I figured it out.....
Very appreciative for your help.
Ninja
Ninjawarrior
Flathead
Ninja
In addition, if the battery is dead in your main FOB you can use it the same way :)
WEll now that is good info!
Ninjawarrior
Come on NW... Don't tell me after all this time and your world of lighting wisdom you didn't know this brutha??  :o   :banghead:   :battle:
Knew about it but never tried it....
Ninjawarrior
