Author Topic: Bottom fairing  (Read 1325 times)
Offline Z71
Bottom fairing
« on: October 06, 2012, 08:11:23 AM »
It's been a while since I changed my oil so do not remember if I removed the bottom gray color fairing to access the oil filter or not.  The shop manual says nothing about removing it.  The drain plug is definitely accessible, and the oil filter should be doable with a properly fitting cap wrench.  Is this a good assumption?
Flathead
Re: Bottom fairing
« Reply #1 on: October 06, 2012, 08:13:14 AM »
Good assumption, no need to remove. :)
Re: Bottom fairing
« Reply #2 on: October 06, 2012, 09:06:14 AM »
No need to remove it.   I have a wrench sold for Goldwings by HDl and it works well. I used a K&N last time so it should be easier.
