Author Topic: Curious about Clearance  (Read 7081 times)
Offline Glennn
    • Metric Rider
« on: September 26, 2012, 06:37:44 PM »
Morning Folks,
So I read a number of threads about peg feelers scraping and even going so far as scraping hardware such as lower farings.
I consider myself a moderate to advanced experienced rider, more than 20 years on bikes and not afraid of getting amongst the twisty stuff.
Thing is, no matter how low I get in a corner I don't scrape the pegs.  Looking at the chicken lines on the tyres if I had to go any lower, especially in left handers, I am sure I would run out of rubber.  If anything I would rather the pegs scrape as that early warning system.
Currently stock tyres at 7,300kms (PR3s going on in a couple of weeks though), I'm about 180lbs, think the rear suspension is turned in about x10.
Thoughts, or is this typical?
1999 Yamaha Road Star
Canberra, Australia
CDA #390
Re: Curious about Clearance
« Reply #1 on: September 26, 2012, 07:03:19 PM »
I like a spirited ride as well as the next guy but if I'm scraping hard parts I'm doing something wrong. And not being RickyRacer, me getting a knee down is a bad thing.  8)
Offline Glennn
    • Metric Rider
« Reply #2 on: September 26, 2012, 07:21:50 PM »
Definitly don't want to scrape hard parts :)
Canberra, Australia
CDA #390
Offline shreveportSS
« Reply #3 on: September 26, 2012, 07:36:50 PM »
I too have yet to scrape more than pegs on the Connie in 13,000 miles. I attribute it to the fact that I get off the side of the bike in tight curves a bit more than those who hang in the saddle given the same curve. That is my excuse.
2011 Concours 14
2011 ZX1000GBF Ninja. Died Dec. 1st, 2012
2012 ZX1000HBF Ninja.
lizardbait
« Reply #4 on: September 26, 2012, 08:05:16 PM »
you"ll love the PR3"s......right to the edge!! :stirpot: :chugbeer:
Offline C1xRider
« Reply #5 on: September 26, 2012, 11:13:56 PM »
Given you're on the stock tires, it's no surprise you've never scraped anything.  I didn't either.  However, once I put some real tires on the bike, that changed.  My right peg has run out of feeler, and has started chewing on the peg itself.  Left peg isn't far behind.
After you put the PR3s on it and get used to them, come back and let us know how it goes.   ;)
Offline Mister Tee
« Reply #6 on: September 27, 2012, 08:32:34 AM »
You can contact the feelers and not run out of rubber.  I don't lean to the point of scraping hard parts, but I do occasionally scrape the pegs.  There is probably about an eight of an inch of chicken strips still left, and a bit more on the front.  I run PR2's, with 42 pounds front and rear.
« Reply #7 on: September 27, 2012, 10:07:03 AM »
Isn't that cause your running Buell pegs Rob? I never scraped my stock pegs, but after I put on Buell pegs I can scrape them making a sharp cut leaving a stop sign.
Offline C1xRider
« Reply #8 on: September 29, 2012, 11:33:26 AM »
I am running the Buell pegs, but if you measure the clearance of the stock pegs and the Buell pegs, the point of contact is the same (or slightly better with the Buell pegs).  Plus, after I've ground off most of the feelers, I should have more clearance than stock.
I'm currently running a 180/55, but I scraped them even with the 190/50.  The next tire (already on hand) will be a 190/55.  I'm hoping it doesn't make the bike too tall for me.  With the 180/55, I'm running out of rubber at the edge on the rear (nearest the sidewall).  There are no chicken strips on the rear, what so ever.  I've had the tire step out on me a couple times on clean dry pavement, which I suspect was due to running out of contact patch.  The front is stock size, and still has 1/8" or so of chicken strips showing.
Tom, now that you are getting more comfortable on the bike, you should try swapping back to the stock pegs as a test, and see if you scrape them.
Offline wipfel
  • 2010 Concours 14 ABS
« Reply #9 on: September 29, 2012, 11:35:56 AM »
Sounds like you are probably positioning your body well.  Often it seems folks think dragging hard parts is a sign of proficiency, but i think it's compensation for poor use of the body.
--If I could be anywhere right now, I'd still be out there, on my bike, in the wilderness.
Offline C1xRider
« Reply #10 on: September 29, 2012, 11:51:21 AM »
In my case it's usually from going a little too hot through the corners.  ;)
I try not to scrape anything, but I also try to push it to the edge.  However, to find the edge requires scraping from time to time.  Then there's always the unexpected bump in the middle of the corner.
« Last Edit: September 29, 2012, 07:27:37 PM by C1xRider »
« Reply #11 on: September 29, 2012, 01:11:33 PM »
Have never dragged pegs on the C14, never seem to have a problem in the twisty bits either. Maybe body position and higher preload settings help?
« Reply #12 on: September 29, 2012, 06:34:36 PM »
That sounds like a good reason to ride tomorrow, I am gonna try that. Maybe I can get Jay to head out your way with me and we could go for a rip. I'll send you a PM if I can get something organized for tomorrow.
Offline C1xRider
« Reply #13 on: September 29, 2012, 07:26:45 PM »
Sweet!  Let me know, I just fueled up on my way home tonight.  I need to get rid of some of that pesky excess rubber on the sides of my tires, so they'll match the centers.  ;)
I've got lots of twisty roads out here you guys have probably never seen too.
« Reply #14 on: September 30, 2012, 12:44:01 AM »
To put it nicer, differant riding styles/positioning and entry speed will result in a differant lean angle and use of the bikes suspension.  The only time I ever drug a peg?  In a parking lot doing the Military Sportbike Class.  Combination of bad form and an abrupt roll off which allows the suspension to colapse, sounds like something Rob may be experiencing (abrupt roll off).  Entry speed, entry point, and body position (no knees please).  FWIW, I've seen the tater launcher scraped at Pacific Raceways.  He got in too fast, early, and shoulders were over the bike, he absolutely chopped the throttle.  He thought it was cool when he saw the scrape, then I told him when he did it, changed his tune and he payed a little closer attention to the lessons/drills being run.
Offline jjsC6
« Reply #15 on: September 30, 2012, 05:47:18 AM »
I don't know why people think that body position keeps you from dragging anything.  Even if you are hanging off you can still scrape stuff.  It's all a matter of how close to the limit folks want to lean the bike over, regardless of body positioning.
Jim
2010 Concours - Sold Feb 2013
Current bikes....
« Reply #16 on: September 30, 2012, 06:17:15 AM »
How much faster than the speed limit are you all going that you scrape parts on the bike?  The only time I've ever scraped anything is when I would take a left turn from a side street onto an off camber roadway.
I have taken 45 mph curves at 65 mph and no scraping.  So, are you all scraping on 25 mph curves at ? mph?
« Reply #17 on: September 30, 2012, 06:23:00 AM »
Because body position does change the angle that the bike leans to navigate a curve at a given speed.
There are a lot of good books out there that explain this.
If you were to keep your body perpendicular to the road surface you would have to lean the bike further to navigate a curve at a certain speed than if you lean your body out on the side of the bike that is in the direction of the curve.
If you look at your windscreen as a solid door instead of a window.  When taking a right curve you want to look around the right side of that door.  When taking a left curve you want to look around the left side of that door.
"Total Control" by Lee Parks is a great read.  As well as "Proficient Motorcycling" by David Hough.
Offline danl
« Reply #18 on: September 30, 2012, 07:26:22 AM »
I scraped a peg for the 1st time last weekend. One of those 25mph curves, went in around 50 and the curve kept closing on me, dragged my boot and the peg for a brief second. I attribute it to incorrect body position. I did the dragon and a lot of the roads in that area at a spirited pace and never dragged anything, so this was a bit of a surprise.
« Reply #19 on: September 30, 2012, 09:44:05 AM »
Thanks......you beat me to it. 8)
