Author Topic: Mondo Motos Auxiliary Lights  (Read 32343 times)
Offline greeni
  • Country: sg
Re: Mondo Motos Auxiliary Lights
« Reply #40 on: October 14, 2012, 06:59:39 AM »
Nice....Wat crash bar are u guys using ...
Asian yes!!! China man. NO!!
Offline Caffeinated
« Reply #41 on: October 14, 2012, 08:15:38 AM »
Those are MC Enterprises Canyon Cages. Two different versions, one for 08-09, and one for10+ models.
http://www.zggtr.org/index.php?topic=7593.0
2012 Black Concours 1400
Offline ljcorby
  • COG#: 9359
« Reply #42 on: October 16, 2012, 06:36:01 AM »
Thanks.  Just received the MM10 kit yesterday and will more than likely be installing them tomorrow, Wednesday, 10/17.  Will let you all know how it goes.   ;D
10 Kawi Concours 14 ABS
Offline ljcorby
  • COG#: 9359
« Reply #43 on: October 16, 2012, 11:41:07 AM »
556ALPHA, where did you mount the switch that came with your MM10 kit?
I have been looking for a set of lights for a while that did not require a dimmer and provided excellent visibility to catch the attention of oncoming vehicles.  These were reasonable in price (apx 150.00 shipped with harness, 110.00 w/o harness.  The harness was easy to install but I will be changing the connectors where the harness plugs into the lights out to a better waterproof style in the future.  They are apx. 1040Lm and are not obnoxious to oncoming drivers at night.  I really wanted the Clearwaters but could not swing the 500.00 price tag.  There is a thread explaining them over on the ADV forum (http://advrider.com/forums/showthread.php?t=751838&page=19) so I will let you guys read all about them over there if you are interested.  I mounted them with the supplied hardware to the reflector brackets and it is a perfect fit.  Here are a few shots:
« Reply #44 on: October 16, 2012, 12:22:58 PM »
As I always keep them on I placed my switch inside the tanks glovebox. If I needed to have it readily available I would have purchased the mounting pas twisted throttle sells for the Denali's.
Offline ljcorby
  • COG#: 9359
« Reply #46 on: October 16, 2012, 12:35:51 PM »
Thanks, I think I may make one out of scraps I have in the garage....thanks for the link.
« Reply #47 on: October 16, 2012, 12:45:20 PM »
I do t blame you on that, I would do the same.  Home Depot has spacers if you need them.
Offline ljcorby
  • COG#: 9359
« Reply #48 on: October 16, 2012, 12:49:49 PM »
Yeah, either there or Lowes....think I will trace the outside edge of the switch, cut her out, clean up the edges, paint her black, add a spacer and go from there.  Thanks.
Offline charliespain
  • Country: es
  • CARPE DIEM
« Reply #49 on: October 17, 2012, 05:31:51 AM »
!Pictures¡...Please
Offline ljcorby
  • COG#: 9359
« Reply #50 on: October 20, 2012, 02:41:50 PM »
Here are some pic's of the install....came out pretty well..
and here are some pics of the switch mount I made.  Not bad.
Couple more....
Let me know what you think.  Thanks.
« Last Edit: October 20, 2012, 03:18:16 PM by ljcorby »
« Reply #51 on: October 20, 2012, 05:48:14 PM »
That is a nice looking mount and great location.
Offline Rasmith
  • Lenexa KS
« Reply #52 on: October 20, 2012, 06:20:19 PM »
lights look great!
Looks like you have some scalloping on that front tire..Or is it the light hitting it
2012 C14 Candy Arabian Red
2007 Vulcan Meanstreak 1600
Offline ljcorby
  • COG#: 9359
« Reply #53 on: October 20, 2012, 06:21:59 PM »
It's the light.
« Reply #54 on: October 20, 2012, 06:23:54 PM »
Looks great Larry!  8) :thumbs:
« Reply #55 on: November 12, 2012, 03:48:52 PM »
Ordered the Mondo lights, and lights from Skene Designs.  Going to mount the Mondo lights outboard on the canyon bars. The Skene Design photon blasters on the fenders and the P3 lights on the rear.  I should be set for riding this winter.  If they hit me they can't say it's because they didn't see me, it will be because they were out to get me.
Offline JoeRau
« Reply #56 on: August 01, 2013, 02:25:31 PM »
Finishing up the install of these today, once the mail comes and delivers the waterproof connectors I ordered.  I mounted them to the front fender bolts, so we'll see if that works out.  I like the install in the reflector mount also, so I may move it back there at some point.  Here are some pics.
Finishing up this and installing the HID kit and air filter today.   Everything will be white when I'm done.
I like that, but does the light beam bounce with the front wheel travel?
2012 C14.  Black
COG member 10990
Offline Caffeinated
« Reply #57 on: August 01, 2013, 02:29:25 PM »
Not that I can tell...they are down low enough that you can't see the light pattern move. I also have HIDs that pretty much overpower the driving lights anyway.
« Reply #58 on: August 01, 2013, 03:15:59 PM »
Only when he wheelies.   :)
Offline JoeRau
« Reply #59 on: August 01, 2013, 03:25:39 PM »
Another location about the same height would be the fairing mount that is just behind the wheel.  I could see the wheel or fender blocking the light when turned.
I'm still curious to see if anyone notices the light beam bounce when mounted on the front wheel/fender/reflector mount.
2012 C14.  Black
COG member 10990
