Author Topic: Mondo Motos Auxiliary Lights  (Read 32340 times)
Offline Caffeinated
Re: Mondo Motos Auxiliary Lights
« Reply #20 on: September 20, 2012, 08:32:36 PM »
Just got my MM10's today.  Need to install them and the A&R 6000k HID kit sitting in the box.  I was going to use the front fender bolt to mount the lights, but it looks like the reflector bolt would be easier (no spacer).  Is that mounting spot sturdy enought to support the lights? They are VERY well made lights.
2012 Black Concours 1400
Offline ljcorby
  • COG#: 9359
« Reply #21 on: September 21, 2012, 07:58:26 AM »
I will more than likely also be ordering the MM10's as well.  Let us know how the install goes and post up some pics when done.  Thanks.
10 Kawi Concours 14 ABS
« Reply #22 on: September 21, 2012, 03:07:28 PM »
Reflector bracket is sturdy enough, I used two small washers to space the lights out 1/8 inch.  You may decide that you do not want to.  Looking forward to your pics.
Offline h2smokin
« Reply #23 on: September 23, 2012, 09:41:31 AM »
I may grab a pair of those as well . Don't need the wiring as I'm ordering a fuse block from eastern beaver and try and do it myself
Offline JS_racer
« Reply #24 on: October 08, 2012, 04:13:36 PM »
Do these help, with low beams cornering at night mounted low? Hate how the headlight beam can go almost vertical and can't see the corners. Thanks.
Offline COGnosticat0r
« Reply #25 on: October 08, 2012, 05:56:26 PM »
Looks like the MM10 light only are sold out
Jerry Holland
COG 4478
2013 C14
Offline Caffeinated
« Reply #26 on: October 09, 2012, 09:01:01 AM »
the ADV page to order is still up, and it looks like just the lights are still available.
http://www.mondomotos.com/product/mm10adv/mm10adv.php
Offline Caffeinated
« Reply #27 on: October 09, 2012, 09:07:59 AM »
Finishing up the install of these today, once the mail comes and delivers the waterproof connectors I ordered.  I mounted them to the front fender bolts, so we'll see if that works out.  I like the install in the reflector mount also, so I may move it back there at some point.  Here are some pics.
Finishing up this and installing the HID kit and air filter today.   Everything will be white when I'm done.
« Reply #28 on: October 09, 2012, 04:45:17 PM »
6000k??  No, everything will be BLUE when you are done ;)
« Reply #29 on: October 12, 2012, 09:31:23 AM »
For anyone considering these lights I suggest following this thread for info.  These are still unavailable to the general public.  BTW they performed great during my recent trip to the Blue Ridge.  The new kits come with waterproof connectors so there should be no issues with the connectors.
http://advrider.com/forums/showthread.php?t=751838&page=23
Offline ljcorby
  • COG#: 9359
« Reply #30 on: October 12, 2012, 10:15:56 AM »
Try this...looks like limited quantities available at this time.   ;)
http://www.mondomotos.com/product/mm10aux/
Offline Caffeinated
« Reply #31 on: October 12, 2012, 12:29:09 PM »
Ok, got everything wrapped up finally.  MM10's installed, 6000k HID's installed, fixed my stripped motor mount on the right side, changed the coolant and air filter.
Waterproof connectors I got off eBay.
Round switch for the lights located in the blatant blank spot Kawi left us. They are also tapped to the accessory lead for switched power.
« Reply #32 on: October 12, 2012, 02:48:43 PM »
Nice install, I thought about placing a switch there but have not decided if I want to put a Powerlet there.  Can you provide a link for those connectors off Ebay?  thanks
Offline Caffeinated
« Reply #33 on: October 12, 2012, 03:08:00 PM »
Sure, this was the cheapest place (perfplusconnection). The instructions call for a special crimper, but I was able to work it using and insulated and uninsulated crimper.
http://www.ebay.com/itm/370612245715
Offline ljcorby
  • COG#: 9359
« Reply #34 on: October 12, 2012, 03:16:23 PM »
Also, just so everyone knows, evidently the new MondoMotos MM10 kits come with waterproof connectors now.  :-)
« Reply #35 on: October 12, 2012, 03:21:54 PM »
Thanks, ironically enough I believe I have that saved in my watch list.
Offline h2smokin
« Reply #36 on: October 12, 2012, 05:27:02 PM »
did you have enough play in the harness to mount on the fender with no worries? Mine should be here tomorrow. Gonna install them and the HID's also next weekend I hope
« Reply #37 on: October 12, 2012, 05:49:39 PM »
although mine are on the reflector mounts there is only about a 5" difference.  There should be plenty of wire.  Worst case scenario you could extend the +/- wires about a foot but I do not think you will have any problems.  I may move mine to the fenders when I change out the connectors, but they look and work good where they are so who knows.
Here is a good comparo:
FENDER MOUNT
REFLECTOR MOUNT
Offline ljcorby
  • COG#: 9359
« Reply #38 on: October 13, 2012, 02:38:22 PM »
Anyone have an electronic copy of the installation instructions for these MM10 lights?  I will be getting mine in a day or so and want to plan the install.  Thx.
« Reply #39 on: October 13, 2012, 05:14:39 PM »
They install fairly easily.  Power to battery, switched power for relay, I used the acc lead.  Ground to chasis.  Light switch to relay.  If you look at the link I posted for the ADV forum thread Toad provides a link to install instructions.
http://www.mondomotos.com/instructions/V2DIAGRAM.pdf
