Author Topic: using the spare key in the fob?  (Read 7569 times)
Offline jschrock1
« on: September 10, 2012, 07:37:29 PM »
I read this snippet in an article about the 2008 concours, but I don't get it?  How can you use the spare key if the FOB battery is dead?  Can you use the small key to start the bike if you don't have a fob?  It didn't work when I tested it, as I figured.;..  I just don't understand the paragraph...
Losing a transponder would be no different than losing a key (though this system can't be overridden by a locksmith, and requires contacting Kawasaki for a replacement.) If the transponder battery goes low, a meter displays a warning; if it goes out, a small key can be pulled out of the unit to operate the bike.
Offline PH14
Re: using the spare key in the fob?
« Reply #1 on: September 10, 2012, 07:46:10 PM »
The manual is a great help on this matter. You can still start the bike with a dead FOB battery by following its instructions, but you still need the FOB.
Offline dras
  • The Invisible Man
« Reply #2 on: September 10, 2012, 10:39:57 PM »
[/quote]
I think what they were trying to convey here is that you can pull out the spare key and place that recessed area of the fob against the front of the ignition key housing and start the bike using the passive capability (the RFID portion) of the fob. Mine works fine this way without pulling out the spare key, but it fits on there real nice with the key removed  ;).
Never get too busy making a living that you forget to make a life.
« Reply #3 on: September 11, 2012, 03:04:32 PM »
Starting the Concours always requires both an RFID fob and a key, period.   The small key is spare to open your panniers (hard bags), open the gas cover door, or replace the stovekey (big key) that is normally left in the ignition.
You should never lose your main key if you keep it in the ignition at all times when not in use for some other purpose, which is pretty much how it was designed to work.  Personally, I *NEVER* remove the main key, because I had a "regular" key cut by a locksmith that I carry to use for the panniers and gas.
« Reply #4 on: September 11, 2012, 03:15:12 PM »
I've heard that using the stove knob key is 'bad juju' unless one does the KiPass dance w/in 20 minutes afterward.
« Reply #5 on: September 11, 2012, 03:16:17 PM »
You forgot the required chant/prayer that must also be recited....
« Reply #6 on: September 11, 2012, 03:30:40 PM »
I believe that is incorrect- if you do the dance w/in the alloted time, you can skip the chant.
Of course those who think they can assuage the system by throwing salt over their shoulder are being foolish and simply tempting the fates.
« Reply #7 on: September 11, 2012, 04:11:53 PM »
Oh yeah, I forgot about that.  You only need the chant if you take too long to do the dance.
« Reply #8 on: September 12, 2012, 04:54:30 AM »
What happens if one dances like this?
Seinfeld - The Elaine Dance
« Reply #9 on: September 12, 2012, 06:40:40 AM »
This is the "winningest" topic on the Internetz today
« Reply #10 on: September 12, 2012, 07:53:55 AM »
I used to could dance like that, but dropping a Buell on my foot ruined me for life  :'(
« Reply #11 on: September 12, 2012, 09:51:37 AM »
 :rotflmao:  I love that episode!  :thumbs:
« Reply #12 on: September 12, 2012, 10:10:15 AM »
Sweet fancy Moses that's some funny stuff!
« Reply #13 on: September 12, 2012, 11:45:44 AM »
Wrong dance C, that is the before E start Harley dance ;)  It still applies to Harleys today, used to kick in a loose gasket ;)
