Author Topic: Lower driver pegs & most recent rear brake pedal recall  (Read 2581 times)
Offline SkipH76
« on: September 09, 2012, 08:44:27 PM »
Anyone with lowered driver pegs - i.e. Murphs or Buell - have any issues with the newest design brake pedal cable?  Does it adjust properly with the lower pegs?
TIA!
Offline BackInTheSaddle
Re: Lower driver pegs & most recent rear brake pedal recall
« Reply #1 on: September 09, 2012, 08:57:52 PM »
I have Buell pegs and I found the new brake linkage easier to adjust and it has as much range as the old one.
Don, Apple Valley, MN
2008 C-14 ABS, AeroFlow Tall, Murph's risers with wedges, Buell pegs, Zumo 590, lowered pegs, Russell Day-Long
Previous bikes 2001 Kawi C10 (RIP), and 1981 Honda CB650
http://i879.photobucket.com/albums/ab353/DonaldHollinger/MOTO/Map_zpse09bb1e5
« Reply #2 on: September 10, 2012, 10:03:40 AM »
I had lowered pegs for awhile and had cut about 1/4" from the threaded rod coming out of the master to allow the brake peddle to be lowered safely without putting any pressure on the master. I didn't like the lowered pegs after all and put it back to stock. The threaded rod was still long enough to put the peddle back to stock as well. I the recall done and no problems at all. As BackInTheSaddleAgain said, it's easier to adjust now and no problems with stock peddle height.
Offline MGvaleri
  • Country: it
« Reply #3 on: September 18, 2012, 07:03:47 AM »
 Con questi nessun problema..made in Fai Da Te.
Prototipo ..Stampi.
MGvalerio. 8)
Offline jayke
« Reply #4 on: September 18, 2012, 10:29:37 AM »
I've got Murphs pegs.  Ok for me after the recall.  Just had them run it down as far as they could.
I have not cut the rod down.
Offline McJunkie
« Reply #5 on: September 19, 2012, 04:51:58 AM »
I've got the Buell pegs and found that run all the way down is still not quite enough. I'm going to see if I get used to it or I will cut the rod this winter when I do the valve clearance check again.
