Author Topic: lugging the motor  (Read 9930 times)
Offline S.Ga.Rider
lugging the motor
« on: May 26, 2011, 07:10:36 AM »
Full throttle in od in lower rpms, pull the clutch in and the bike will shut off.
« Last Edit: June 24, 2011, 10:37:01 AM by S.Ga.Rider »
Offline Shoe
Re: bike shutting off
« Reply #1 on: May 26, 2011, 07:20:33 AM »
There are times when you have to take your bike to the dealer.  :'(  This sounds like one of those times. Remove anything that is not stock before you bring it in.
On the other hand it's probably a loose connection.
Eat corn. Drill for oil.
2008 Concours, 2010 Goldwing
Offline S.Ga.Rider
« Reply #2 on: May 28, 2011, 07:43:21 AM »
So I guess I am the only one with this problem?
« Last Edit: June 24, 2011, 10:50:54 AM by S.Ga.Rider »
Offline Tactical_Mik
  • Lamh laidir an Uachtar
« Reply #3 on: May 28, 2011, 11:25:35 AM »
I was interested in this.  I gave it a try twice, 60 to 75 wot then pull in the clutch.  While I usually don't lug the motor that way my bike did as yours did.  Interesting indeed.  My bike runs perfectly save this instance.
« Last Edit: May 28, 2011, 05:04:36 PM by Tactical_Mik »
T.S.R.
« Reply #4 on: May 28, 2011, 11:37:31 AM »
Hmm, I'll have to try mine as well but it won't be until tomorrow...strange days indeed.
Offline Astrobob
« Reply #5 on: May 28, 2011, 01:17:24 PM »
I went out on my 2009 for a ride and did exactly what you had requested by going from 50-70 in OD and then pulling in the clutch. The bike went to idle when I tried it twice. Hope that helps. Bob
Offline Shoe
« Reply #6 on: May 28, 2011, 02:17:27 PM »
Could this be an electronic rev limiter switch intended to prevent the bike from over reving when you pull on the clutch at high rpms?
Offline S.Ga.Rider
« Reply #7 on: May 28, 2011, 04:06:03 PM »
Idle adjustment helped but still didnt fix the problem.
« Last Edit: June 24, 2011, 10:37:54 AM by S.Ga.Rider »
« Reply #8 on: May 28, 2011, 05:15:51 PM »
Just to keep the confusion down, when I did this I pulled in the clutch and let go of the throttle at the same time.  I also didn't try it 4th or 5th just 6th.  On my way home, from a stop sign I did it in 2nd.  Starting at the same rpm, about 3 grand and did not achieve the same results.
T.S.R.
Offline S.Ga.Rider
« Reply #9 on: May 29, 2011, 07:02:35 AM »
Mine wont do it in the lower gears either, od but runs perfect otherwise.
« Last Edit: June 24, 2011, 10:38:26 AM by S.Ga.Rider »
« Reply #10 on: May 29, 2011, 07:20:21 AM »
Maladjusted throttle cables perhaps?  This is a puzzler.
« Reply #11 on: May 29, 2011, 01:36:22 PM »
I can say my throttle cables are prrrrfect.  Barely any wasted space and I can put negative pressure on the grip and no lowering in idle.  But that is just mine.  I wonder if the ecu has a hard time adjusting the amount of fuel/air that quickly during a shut off.   Just thinking out loud.
T.S.R.
« Reply #12 on: May 29, 2011, 03:53:34 PM »
I would say no, but I've had two martinis and can't think straight at the moment.
« Reply #13 on: May 30, 2011, 06:49:59 AM »
Pain killer for that finger?
« Reply #14 on: May 30, 2011, 06:52:43 AM »
Yes...I wonder why the bleeding won't stop.
« Reply #15 on: May 30, 2011, 06:58:32 AM »
Get your thumb out of the glass fool!
Offline Corpssgt
« Reply #16 on: May 30, 2011, 08:25:31 AM »
I remember reading about how the Connie ecu treats on throttle to off throttle transitions that it actually shuts fuel off or almost off during off throttle conditions. I would suspect that has something to do with it. What happens when you don't shift like a (edited). My bet would be the bike performs normally under normal conditions.
« Last Edit: May 30, 2011, 12:20:30 PM by vajim »
« Reply #17 on: May 30, 2011, 11:23:57 AM »
Maybe you could give us a demonstration so we know what not to do.
« Last Edit: May 30, 2011, 12:20:50 PM by vajim »
« Reply #18 on: May 30, 2011, 12:19:11 PM »
Let's refrain from name calling, at least while the mods are watching.
Offline Shoe
« Reply #19 on: May 30, 2011, 01:27:00 PM »
Can someone please steer this thread back on topic or lock it?
