Author Topic: Newbie. Horns? Gimme sometin else beside stock?  (Read 2962 times)
Offline robert.h.weinstein
« on: September 01, 2012, 12:31:31 PM »
2012 Connie 14 ABS in Sac Calif.
Bought a Stebal and crappo! There ain't not place to mount it. Inside faring nor outside on Shocks.
Kawa used up every piece of space on that darn thing.
Is there anything loader than the oem MEEPER horn (db generated is still unknown) that can be mounted in its place?
Thank you all :-)
Offline texrider
Re: Newbie. Horns? Gimme sometin else beside stock?
« Reply #1 on: September 01, 2012, 12:35:26 PM »
I bought a small Attwood boat horn from Academy, and put it in place of the original. It's about the same size, weatherproof design, and marine horns are rated to be heard for one mile. It is a lot louder than stock, and lower toned.
http://www.attwoodmarine.com/store/product/Hidden-Horn-Kit
2014 Valkyrie
Yo Tex, Just Called Kawa store locally they suggested 115 db Piaa
« Reply #2 on: September 01, 2012, 01:18:01 PM »
http://www.amazon.com/85112-115db-500HZ-600HZ-Sports/dp/B00079V5ZI/ref=pd_sim_auto_1
or here
http://www.motorcycle-superstore.com/3/13/123/17147/ITEM/PIAA-Sports-Horn.aspx?SITEID=Google_PIAA_Sports_Horn&WT.mc_ID=10001&WT.srch=1&esvt=GOUSB340920207&esvadt=999999-0-4005425-1&esvid=400070&gclid=CNX5kIGLlbICFWXhQgod4FIAfg
PIAA 85112 115db 500HZ + 600HZ Sports Horn
Remove and replace apparrently
Each 10 db results in doubling the sound volume soooo...
So if your suggestion (105 db) is better than the OEM than the (115) db Piaa would be double yours?
Hmmmm?
TY
« Reply #3 on: September 01, 2012, 02:50:34 PM »
Thank you all :-)
Welcome! Before you post questions, always search the forums first.  There are plenty of threads on this topic already.
http://www.zggtr.org/index.php?topic=286
http://www.zggtr.org/index.php?topic=3104
http://www.zggtr.org/index.php?topic=10349
http://www.zggtr.org/index.php?topic=7531
http://www.zggtr.org/index.php?topic=9306
http://www.zggtr.org/index.php?topic=639
http://www.zggtr.org/index.php?topic=2821
http://www.zggtr.org/index.php?topic=2939
http://www.zggtr.org/index.php?topic=3129
http://www.zggtr.org/index.php?topic=8759
http://www.zggtr.org/index.php?topic=8845
http://www.zggtr.org/index.php?topic=7892
« Reply #4 on: September 01, 2012, 03:07:50 PM »
Attaboy Max. :)
Offline gthomas15229
  • 2011 C14 Black
« Reply #5 on: October 06, 2012, 01:18:33 PM »
Pepboys has a 132 db Low Tone Fiamm that fits nicely. You do have to remove the rubber bushing since the Fiamm mounting screw is shorter. They also have a High Tone version but not sure what it sounds like yet. I had purchased a set for my wife's previous car, but we traded it before I got a chance to mount them. What luck...who knew that I would have to replace the C14 OEM tweeter after only 4 days.
'06 C10 gone to salvage heaven
New ride 2011 C14 Black new left over
