Author Topic: Front caliper piston diameters?  (Read 1541 times)
Offline Mike G
« on: August 26, 2012, 06:33:00 PM »
Does anybody know the piston diameters of the stock 2 piston 94+ front calipers?
I'm wondering how much more/less piston area the Tokico 4-pots I'm installing have, they have 30mm pistons.
Thanks
Mike G
Offline Mike G
Re: Front caliper piston diameters?
« Reply #1 on: September 13, 2012, 08:11:34 AM »
For anyone interested, the 94+ piston diameters are 34mm and 27mm so the early style (94 ZX-6) 4-pot Tokico have 95% of the piston area of the 2-pot.  I'm hoping the 4-pots are stiffer than the stockers and will eliminate the sponginess and long travel at the lever.
Mike G
« Last Edit: September 13, 2012, 04:00:15 PM by Mike G »
Offline Daytona_Mike
« Reply #2 on: September 13, 2012, 05:28:54 PM »
Order the  S.S. 2 line  system from Murph's. That is the only thing that will fix that issue.
