Author Topic: traction control  (Read 3278 times)
Offline scootertrash
traction control
« on: August 19, 2012, 10:33:27 PM »
on 10' and newer, can u get ktrac and abs seperate, or are they a package deal? Like ktrac without abs, or versa visa. Sorry for a ignorance, I am a rook.
Re: traction control
« Reply #1 on: August 19, 2012, 10:47:05 PM »
They are one in the same...
« Reply #2 on: August 19, 2012, 11:20:19 PM »
The 10 was available in non-ABS I believe.
« Reply #3 on: August 20, 2012, 04:17:35 AM »
And if you get the non-ABS then you don't get traction control.  Starting on the 11's on up is when you don't have a choice...you get ABS and traction control.
« Reply #4 on: August 20, 2012, 10:25:48 AM »
I see, said the blind man to his deaf brother.
Thanks for the info. out.
« Reply #5 on: August 20, 2012, 03:22:33 PM »
* Gen 1 bikes (2008-2009) did not have a traction control option, but did have an ABS option.
* 2010 bike had a combination of the two (ABS/Traction Control) as an option.  They cannot be separated.
* 2011+ it is standard equipment (not optional)
Traction control can be disabled by the handlebar controls, but I think you have to do it each time you start the bike (I have never done this, never plan to, either).
« Reply #6 on: August 20, 2012, 09:17:35 PM »
thanks for responding.
 Is the abs/ traction control system  good, or is it like the chevy camaro trac. cont. in 2000, where it totally ruins braking, even in dry conditions in a straight line? Just wondering if it's a quality system, or if it was designed in tijuana in a roach coach? The tc, abs is great in theory, but it fail's in application when engineer's have to design it with time or price constraint's.
Camaro tc/abs is the worst(have one), while the abs on the svt cobra mustang was supremely awesome. Alas, the tc from ford kinda sucked a bit, though. thanks
« Reply #7 on: August 20, 2012, 09:54:30 PM »
I had a 97 Cobra Mustang with the DOHC 4.6. It had amazing brakes. My 08 C14 will out brake it in every aspect. The antilocks are very good.
« Reply #8 on: August 20, 2012, 10:16:39 PM »
thanks. I will try to ride one with abs then and do a little experiment. Appreciate the reply.
Offline usttobee50
  • She rides a Harley,and I thought I wanted a C-14
« Reply #9 on: August 20, 2012, 11:01:57 PM »
Traction control can be disabled while moving....but why would one want to???
« Last Edit: August 21, 2012, 05:10:00 PM by usttobee50 »
Ride Safe....Usttobee50
2005 Mean Streak, Pearl Magma Red
2011 C-14, Atomic Silver
Offline jonathan
« Reply #10 on: August 21, 2012, 07:43:16 AM »
Traction can be disabled while moving....but why would one want to???
So that you can pop a wheelie?
« Reply #11 on: August 21, 2012, 06:40:01 PM »
Good answer.
