Author Topic: Juice Box  (Read 1691 times)
Offline pcaddict66
Juice Box
« on: August 16, 2012, 10:35:00 PM »
Anyone try the Juice Box from 2 bros?  I know it does not allow the full customized tuning adjustments as the Power Commander but I am interested in it for its ease of use. It adds fuel to the mix at custom points in the rpm range and breaks these options down based on throttle input. They call it Cruising, Accelerating and Full Throttle and the device allows adjustment for each of these settings.
I am hoping it will smooth out my throttle response when I re-accelerate after slowing down. Currently I get a delay or hesitation and some flat spots when cruising..  It is supposed to help smooth out the response throughout the range.
I am not looking for horsepower gains. I just want to get my bike to run smoother as it did before putting on my slip-on. They can be had for as low as $230 online.
Thanks in advance.
Offline sas mayhem
Re: Juice Box
« Reply #1 on: August 17, 2012, 04:56:35 AM »
 :popcorn:
I'm interested in this too,  the PO of my '09 already had it installed. But I have not messed with any settings yet. So it still in stock configuration.
Cheers
Ron
09 Connie
Offline Deathwish
Re: Juice Box
« Reply #2 on: August 17, 2012, 11:04:48 AM »
I've been running a Juice Box for over a year now. It uses Power Commander maps, plus you can store multiple maps and change them on the fly if you want. Works great! I've had no issues with it at all and would highly recommend it. Currently running a map for a Two Brothers slip on and flies out.
