Like MOB's bike, my 09 when cold is about 1400 cold then drops back to about 1100 warm (adjusted).
Ah, indeed. I think the vital info may be here. Just out of interest, is the adjustment referred to in the workshop manual anywhere? I ask, because I did look through it to find out any fast idle info and couldn't find it.
Idle is about 1000 when cold and a couple hundred more warm.
I decided to see if I have the secondary butterflies. Turns out I don't.
Also, I can't seem to find them either on eBay or on the parts catalogue (unless I buy the whole throttle body). Does anyone know of a workaround? Someone who can supply just the flaps maybe???
Well... it didn't go too well. Made some adjustments, which helped with the cold start idle speed.
Whilst I was out, I decided to see if I have the secondary butterflies. Turns out I don't. Also, I can't seem to find them either on eBay or on the parts catalogue (unless I buy the whole throttle body).
HERE... GRAB THEM FAST.....
Went in pretty uneventfully. I noticed it pulls much easier, more keen to accelerate. Very clean through the revs.
First- a big shout out to Lather for sending me his spare secondaries. Thank you so much, I really appreciate it.
Went in pretty uneventfully. I noticed it pulls much easier, more keen to accelerate. Very clean through the revs. It's still a bit snatchy and kind of kicks as I start to open off of idle sometimes. I did notice one of the inlet rubbers was kinda crumpled, but it doesn't seem to be leaking air.
I've run out of time for this issue for now, but I'll investigate in spring, when I do a full service.
Thanks to all for your advice.
