Author Topic: Accessory Plug not working?  (Read 5568 times)
Offline stelt
« on: June 25, 2013, 07:13:51 PM »
Checked fuse OK, checked socket and have no power at socket...anyone ever have a bad socket?
Re: Accessory Plug not working?
« Reply #1 on: June 25, 2013, 07:45:18 PM »
Not that I recall.
Offline PH14
« Reply #2 on: June 25, 2013, 08:37:44 PM »
Have you checked it with a voltmeter or tried another accessory cord?
« Reply #3 on: June 25, 2013, 09:22:42 PM »
Not to be too obvious but you are checking the outlet with the ignition on, right? It is only powered up when the ignition is on.
Except for the guy on the other forum who has a C-14 that he claims the cigarette lighter outlet stays hot for a while after he shuts the ignition off. In the grand scheme of things, this sort of balances out the entropy in the universe- you do not have enough 'outlet ON' and he has too much of it.  :D
Offline RBX QB
« Reply #4 on: June 25, 2013, 10:51:37 PM »
And check that it's not just loose. Other threads talk about accessory plugs being loose in the factory socket (and the need to wedge the plug in there).
2011 Concours 14 ABS
Offline Glennn
    • Metric Rider
« Reply #5 on: June 25, 2013, 11:16:59 PM »
Just in case you have a heated Corbin seat - make sure you hook it up properly.  I misread the instructions which knocked out the accessory plug on the dash for a while...
1999 Yamaha Road Star
Canberra, Australia
CDA #390
Offline mvjr1904
« Reply #6 on: June 25, 2013, 11:35:47 PM »
Never tried mine since day one. Guess now I better give mine a try.
2011 Silver C14 - Fastest
2002 Silver C10 - Fast
Offline PH14
« Reply #7 on: June 26, 2013, 10:05:58 AM »
I though of adding that after I wrote my response but decided against it.  :rotflmao:
« Reply #8 on: June 26, 2013, 04:21:15 PM »
:)  Me too
Offline PH14
« Reply #9 on: June 27, 2013, 10:35:18 AM »
Crap, yet another thread without an ending. I'll never be able to sleep if this keeps up.  :doh:
« Reply #10 on: June 27, 2013, 01:54:45 PM »
I'm betting on what Brian said and the OP is a lil embarrassed...
Offline PH14
« Reply #11 on: June 27, 2013, 02:16:15 PM »
Come on, share the embarrassment! We all do things like that. We deserve to laugh at the other who get caught!  ;D
Offline stelt
« Reply #12 on: June 27, 2013, 05:37:17 PM »
Sorry guys...yes i tried with the ignition ON and bike running   ;), no go.. pulled fairing and voila the previous owner had damaged the wiring leading to the socket....all fixed up now... 8) 8)
« Reply #13 on: June 27, 2013, 06:31:26 PM »
I remember seeing that wiring when I was back there and thought "damn that wiring to the accessory socket is thin/wimpy!"
Offline PH14
« Reply #14 on: June 27, 2013, 10:40:37 PM »
Awesome! Good to hear.
Thank you and goodnight, I can sleep now.
Offline TallyRex
« Reply #15 on: June 28, 2013, 03:41:11 AM »
First time I tried to use mine on a new 2012, it didn't work. Checked the fuse and it was blown.  Something must have caused that fuse to blow so I took it to the dealer who couldn't find anything wrong so he put in a new fuse.  That was 2 months ago and it it working fine now, but SOMETHING must have caused that fuse to blow.
Offline PH14
« Reply #16 on: June 28, 2013, 10:55:25 AM »
You never know if someone plugged a bad cord into the socket that was shorted. I wouldn't worry too much about it. Of course you could have a badly insulated wire... Carry an extra fuse. I doubt you'll have another problem. Who knows, maybe the mechanic setting up the bike used the socket to hold his screwdriver.
