Author Topic: brake levers  (Read 4598 times)
Offline F-106
brake levers
« on: January 21, 2012, 11:40:00 AM »
Does anyone have the link to the clutch and brake levers some of you got from china? Thanks
IN THRUST WE TRUST
Offline Outback_Jon
Re: brake levers
« Reply #1 on: January 21, 2012, 01:13:17 PM »
http://www.ebay.com/itm/290519791573
I'd guess those are the ones you'd be looking for.
No affiliation, etc...
Offline Tele130
Re: brake levers
« Reply #2 on: January 22, 2012, 08:21:23 AM »
Yep, them be the ones. :thumbs: ;D
Doug Colton
Offline F-106
Re: brake levers
« Reply #3 on: January 22, 2012, 09:41:51 AM »
Doug, I take it you like them and they have work for you. No issues on install?  THANKS, BILL
IN THRUST WE TRUST
Offline Daytona_Mike
Re: brake levers
« Reply #4 on: January 22, 2012, 04:13:13 PM »
I have a set and like them.  I did have a very minor issue with the brake side. It would not contact the switch so I have to grind off  a little material off the stop plate. Very simple and it  only took a minute.
Offline Tele130
Re: brake levers
« Reply #5 on: January 22, 2012, 08:59:23 PM »
Hi Bill.  Yes, I like them a lot.  No issuses what so ever.  10 min swap job. :thumbs:
Doug Colton
Offline sas mayhem
Re: brake levers
« Reply #6 on: January 23, 2012, 11:35:04 AM »
Ditto, I too have had no issues with the install.
Cheers
Ron
09 Connie
Offline datsaxman@hotmail.com
Re: brake levers
« Reply #7 on: January 23, 2012, 11:56:47 AM »
Another happy user...sets on the Kawasaki and the Buell went on in a few minutes, fit correctly, and have lots of miles on them with no trouble at all.
saxman
161.5RWHP on the dyno
Formerly Silverdammit!
Offline yoman
Re: brake levers
« Reply #8 on: January 23, 2012, 12:38:15 PM »
Okay dumb question,  what is the benefit over stock levers??
2002 Semi-naked Connie
Offline Tele130
Re: brake levers
« Reply #9 on: January 23, 2012, 01:52:56 PM »
Besides the BLING factor, they feel a little more solid then the factory levers  The leading edge (where your fingers come in contact with the lever) is flat, not rounded like the stock one. And you have a little more adjustment options with these.
Doug Colton
Offline Outback_Jon
Re: brake levers
« Reply #10 on: January 23, 2012, 03:53:04 PM »
They also have that neat "break off point" so if you drop the bike and the lever hits, it breaks (or is supposed to) in a spot that still leaves you with a usable lever.
Re: brake levers
« Reply #11 on: January 23, 2012, 04:18:14 PM »
While I can't comment on the "feel" of the knock off levers I can absolutely tell you that the feel from the original PAZZO branded levers is night and day better than the stockers; solid and precision are just two words that come to mind. Also with the increased adjustment range that these levers provide I find myself tuning them in for the gloves that I wear or even for the type of riding I find myself doing at that given moment whereas with the stockers I just lived with the one position that felt better than the rest.
Offline Two Skies
  • Road? What road?!?
Re: brake levers
« Reply #12 on: January 23, 2012, 04:50:17 PM »
Having broken a lever on two occasions now, I can vouch that I count myself lucky that when just the round ball end broke off the second time, I was a much happier camper.  Noting the 'notch' in those chinese levers makes me want to break out the dremel and similary notch my other lever, or just cut off the round end altogether.
As I use the inner parts of the lever anyways to brake, having an end whacked off of my lever really doesn't bother me.  I suppose if things started to bind it might become an issue, but I have strong fingers to begin with.  Plus, this protects the handle a bit as the bar end now extends an inch or two past the brake handle.
Damn drunk guy knocking my bike over anyways...
Offline F-106
Re: brake levers
« Reply #13 on: January 24, 2012, 08:52:18 PM »
THANKS GUYS!!!!!!!!
IN THRUST WE TRUST
Re: brake levers
« Reply #14 on: January 24, 2012, 10:53:26 PM »
+1 to adjustments.  For type of riding, thickness of gloves, hand fatigue from repetitive motion
+1 to the thicker, flatter surface.   Less fatigue, and feels more solid
Add +2 for SHORTY levers for me.  Makes it easier to hold the grip and clutch...or use front brake and throttle simultaneously.  If you are strong enough, one or two fingers should be plenty for street braking.  Keeps your throttle hand from getting pinched by the brake lever sometimes too.
saxman
Offline Vic Salisbury
Re: brake levers
« Reply #15 on: January 26, 2012, 08:07:04 AM »
Ditto to all the positive remarks already.
I really like the feel and the extra adjustment, plus easier to "adjust" with the lever.
like to add, I did have to tighten up the screw and nut on the lever a smidgen, they were a little loose for my taste out of the box. (some settling of contents during shipping I guess)
Second, I ordered the black at the beginning of summer, well, the Floor-e-duh sun down here faded them to a really cool looking gunmetal finish, so I don't mind.
Vic Salisbury
COG #3673
'97 Concours "Grinch"
Sarasota, FL
Offline Matt L
Re: brake levers
« Reply #16 on: January 26, 2012, 04:09:41 PM »
Why are these only good for 1992-2006?
Re: brake levers
« Reply #17 on: January 26, 2012, 04:25:40 PM »
That is because the pre-92 did not have adjustable levers; but trust me they will work on all years. I've read of numerous members who put newer style levers on older master cylinders without issue. So these knock off levers will work on all years; they just don't know because they only go by what the book says.
