Author Topic: [Q] what else to change/inspect while fairings are off (C14 - '08)  (Read 2489 times)
Offline worker
I had first taken the fairings off to replace air filter.
While I knew I wanted to replace coolant, I did not realize that would require same (even more) work to take fairings off.
Now that I have them off for the coolant change, what else can check/replace?
I bought a used one at 25K miles and sofar had changed all the fluids and air filter (I ride in winter time as well).
Re: [Q] what else to change/inspect while fairings are off (C14 - '08)
« Reply #1 on: October 10, 2015, 02:34:59 PM »
cam sensor o ring on front left side.... I sell them, 2 for $1....
http://www.zggtr.org/index.php?topic=13866.0
Offline zarticus
« Reply #2 on: October 10, 2015, 03:55:04 PM »
Check the nuts holding the header to the motor, After 25,000 miles mine were VERY loose.
1986 Honda V65 Magna - Black
1984 Honda V65 Magna - Black
Offline worker
« Reply #3 on: October 11, 2015, 03:16:32 AM »
Yep,
they were loose. Tightened them up.  Thank you!
« Last Edit: October 11, 2015, 11:41:43 AM by worker »
Offline worker
« Reply #4 on: October 11, 2015, 03:20:03 AM »
Thank you.There seems to be some dirt there around cam sensor and the upper gasket. But not substantial. I will wash off the whole thing tomorrow. And will see if it there are any spots after running.
It seems like I would have to take the radiator hoses off to reach to that cam sensor, and I had already flushed and refilled with new coolant.  Otherwise, I would do the o-ring change as preventative anyways.
« Reply #5 on: October 11, 2015, 02:14:59 PM »
you can disconnect the radiator mounting bolts, and carefully lay it forwards on the fender, on rags or a piece of cardboard without removing the hoses.
That will give the clearance you need to do the o ring... if there is any oil leaking now, do it, it will just get worse. Just saying this because at some point when it does leak, pulling all that plastic up front is a real pain.... btdt.
« Reply #6 on: October 12, 2015, 05:27:12 AM »
Good tip.  Thanks, Rich.
