Some pictures and directions for Snarf's Highway pegs.
First remove the lower and side fairings. and the the lower heat shield.
Then remove the mid radiator frame bolt.
install the bolt for to replace the frame bolt, use a 9/16 box wrench.
Cut a hole in the lower shield, now you can cut out just what you need or cut a semi circle in the shield.
Install the plate at a nice downward angle making sure it's not too far down as to prevent it from going through the fairing.
Install the peg and replace the plastics.
More pictures with the pegs installed after a ride coming soon.
On a side note, Snarf told me and later I proved, the fairing can be slipped on over the pegs so they don't need to be removed when removing and installing the fairings. This install was done on a 90 Connie. As far as a review I love them, its great to get my legs out from behind the fairing and related heat. And the color matches what I have done to the inner fairings.
