Author Topic: C10 Right Front Turn Signal Lens  (Read 2240 times)
Offline Alpha One Nine
« on: April 28, 2012, 10:13:51 PM »
I need a right front turn signal lens for my 95 C10 with all three mouting tabs intact.
Thanks
Rick
1995 ZG1000 - The Road Bike
2005 WR450F - The Dirt Bike
2005 KLR650 - The KLR
Offline Stasch
Re: C10 Right Front Turn Signal Lens
« Reply #1 on: April 30, 2012, 08:13:36 AM »
I may have one.  I will check tonight after work and get back to you.
Offline kzz1king
« Reply #2 on: April 30, 2012, 10:29:16 AM »
I might too if Stasch doesn't.
Wayne
2010 CONCOURS
1974 Z-1
« Reply #3 on: April 30, 2012, 12:07:35 PM »
Great!   Thanks guys
Rick
Offline Stasch
« Reply #4 on: April 30, 2012, 08:14:51 PM »
I have 2 right side lenses but unfortunately, don't have one with all 3 tabs intact.
The orange lens is in very good condition on both of them.
I've had success plastic welding tabs on these, but I don't have one ready to bolt on.
« Reply #5 on: April 30, 2012, 09:46:34 PM »
Thanks for checking Stasch,  My orange lens is fine too.  I busted the bottom tab off last fall.  I had the broken off piece and was hoping to weld or glue it back together but now I can't find it.
Rick
Offline Stasch
« Reply #6 on: May 02, 2012, 02:00:07 PM »
I thought maybe your lens face was broken.  You can fix this.
All you need is some polypropelyne (sp?) and a soldering iron.
Any broken black plastic parts from the bike you may have around will work.  Fairing parts WON'T work, they're ABS.
I cut off a tab from a lens that had a broken face, but you could cut and bend a tab from scrap in the shape you need.  Use the soldering iron to weld it onto the black plastic body of the lens.  No need for adhesive.
Practise first on some scrap to get the feel for melt point etc.
Make sure and ventilate your work area well - strong fumes.
Some pics:  Link To Turn Sig Fix
« Reply #7 on: May 03, 2012, 11:20:01 AM »
Thanks for the info Stasch,
I'm still hoping to find that broken off tab so I can weld it back on.  If not, I'm sure I can find something.
Rick
