Author Topic: Once again, 2 line vs. 3 line SS brake lines  (Read 13759 times)
Offline Stasch
Re: Once again, 2 line vs. 3 line SS brake lines
« Reply #20 on: May 24, 2011, 08:03:35 AM »
If you have after market bars, and depending on how they are adjusted, you may find that the 2 line stack on the front master cylinder can come in contact with the fairing's instrument shroud.   Just something to watch for.
Offline throb
« Reply #21 on: May 24, 2011, 06:07:44 PM »
Stock bars on 1.25" risers is what I have, but I remember this possibility from the pre-crash forum.  Not worried about the double stack banjos because when I turn my bars hard right, the very front edge of the front brake level contacts the dash panel before a double stack ever would.
