Author Topic: What are you listening to RIGHT NOW?  (Read 347175 times)
Re: What are you listening to RIGHT NOW?
« Reply #1240 on: August 22, 2020, 08:59:22 AM »
Ug, I must be a glutton for punishment.  I ordered the XM4 last night and picking it up later today.
There will be no punishment, only music to your ears (depending, of course, on your choice of music).  :cool:
Let me know how/if you like/love em.
Don't forget the app for your cell.
Also, you have to do some digging and reading for this but if you use the phone app to change the EQ settings (any setting other than off) you will turn off DSEE (Digital Sound Enhancement Engine). If you've been doing some reading on these phones then you know what DSEE is and what it does.
Seen this?  https://helpguide.sony.net/mdr/wh1000xm4/v1/en/index.html
Here's the help guide for the cell phone app, Sony Headphone Connect.  https://helpguide.sony.net/mdr/hpc/v1/en/index.html
« Reply #1241 on: August 22, 2020, 09:43:09 PM »
There will be no punishment, only music to your ears (depending, of course, on your choice of music).  :cool:Let me know how/if you like/love em.
Well, the sound on these headphones is pretty fantastic, especially after I adjusted the EQ in the app.  They are very comfortable on my ears, although the top of my head hurts after using a while (similar problem I have with helmets).  The noise cancellation is impressive, also.  So, too, is the range- MUCH better than my cheesy bluetooth earphones.  The controls are quite good, and the voice controls are also good.  Haven't tried with phone calls (might never); also have not tried multi-connect.
The up to "30 hours" claim depends mostly on DSEE- it must be off.  With DSEE on (and noise cancelling on), it is only claimed for 18 hours (a MAJOR loss)!  Honestly, I can't tell much difference with DSEE on/off.   I would probably never use it with noise cancellation off (which would jump it to a claimed 38 hours).
The lack of a real "off" persists in this model- the "off" battery life is only 200 hours- that is one of my fears.  It means after just 4 days of not being used and "off", it will have lost HALF the battery charge; leave it "off" for a week and it will be completely dead.  So one has to charge it all the time.  I don't understand why these devices can't have an actual "OFF"; they can't be awakened by anything but a button press and don't DO anything when "off."  The only thing I can think of is bootup time.  I don't know about you, but I would rather have the option of a several second startup time if it meant I can store them as long as I like, knowing the battery is going to be almost where I left it, instead of dead when I want to use them.
Despite the top-head pressure and no actual "off", so far I am happy.
There is no mention of that anywhere in the manual or anywhere else I can find.  Why do you think DSEE turns off if the EQ is not set to off?  Interestingly, there is no "on" setting, only "auto" or "off" so one doesn't really know when it is on or off in "auto."  Considering how much battery DSEE consumes, perhaps it being off is a good thing, anyway?
« Reply #1242 on: August 23, 2020, 07:11:21 AM »
Turning off the headset
Press and hold the  (power) button for about 2 seconds until the indicator (blue) turns off.
Hint
You can also turn off the headset with the “Sony | Headphones Connect” app.
The headset will automatically turn off after 15 minutes of not being worn. This setting can be changed using the “Sony | Headphones Connect” app.
When storing the headset in a bag, etc., turn off the headset. Wearing detection may react incorrectly.
« Reply #1243 on: August 23, 2020, 07:31:32 AM »
As for the DSEE. This is what the manual says about the XM3.
About the DSEE HX function
The DSEE HX function upscales the compressed sound source data such as CD or MP3 to quality almost that of High-Resolution Audio quality and reproduces the clear high-range sound that is often lost.
The DSEE HX function is available when you set as follows by using the "Sony | Headphones Connect" app.
DSEE HX -Auto
Connection - Bluetooth
Codec - SBC or AAC
Sound Position Control, Surround (VPT), Equalizer - All OFF
I found the same info above when I was reading through the manual for the XM4 but I can't seem to find it right now. You'll either have to take my word for it, or not.
« Reply #1244 on: August 23, 2020, 07:36:19 AM »
Listening to Paul Simon - Diamonds On The Soles of Her Shoes
Max, check this song out on your new headphones.    :thumbs:
« Reply #1245 on: August 23, 2020, 08:17:40 PM »
Turning off the headset  Press and hold the  (power) button for about 2 seconds until the indicator (blue) turns off.
I know how to turn it "off", I didn't know if this "off" was the same fake "off" as my old pair I returned (which was not really off, but in some strange "standby" mode with no actual off).  It could be I am misreading what they are saying on page 21 with the incorrect assumption it acts the same as my old pair.  They don't define what "standby" means, but now that I read it again a couple of times, and in better context, I think they mean when the headset is "on" but not playing music.  Yep, I think that is what they mean.  The 200 hours is when not playing music, not using NC, not using ambient sound, and apparently also not connected via bluetooth-  but why would you do that?  It can't even take a phone call or do ANYTHING in that mode.  Maybe with a wired connection?  So this is probably not a problem, after all.  I like Sony equipment (and have LOTS of it) but have never been that impressed with their manuals.
I can't find ANY of that wording in the manual (and I tried many different searches).  Perhaps you are remembering from the XM3 manual and thought it was in the XM4, also?
« Reply #1246 on: August 24, 2020, 07:28:59 AM »
Snip...
No, I'm positive that I read this. I was comparing the XM3 to the XM4 and I had both of the online manuals open on my computer, side by side.
The info for both was in tabular form and it clearly stated what I was saying. I'm not going to look for it any longer though, since I don't have the XM4.
« Reply #1247 on: August 31, 2020, 07:10:09 AM »
For you sax lovers....
https://youtu.be/O-Q6A2HV-tU
« Reply #1248 on: November 08, 2020, 09:59:46 AM »
Rare Earth - I Just Want to Celebrate
https://www.youtube.com/watch?v=VRVPLPFoJL0
Kool & The Gang - Celebration
https://www.youtube.com/watch?v=3GwjfUFyY6M
« Reply #1249 on: November 08, 2020, 02:01:38 PM »
It's the end of the world as we know it.
https://youtu.be/8OyBtMPqpNY
We Didn't Start the Fire
https://youtu.be/dhqH4QpSgBI
as rome burns
https://youtu.be/jv5_PtpgaUc
« Reply #1250 on: November 09, 2020, 06:17:03 AM »
Tell Me A Little Lie To Remember You By - Huey Lewis And The News
https://www.youtube.com/watch?v=RVTPtPkWzgU
Little Lies - Fleetwood Mac
https://www.youtube.com/watch?v=uCGD9dT12C0
Offline Strawboss
« Reply #1251 on: November 09, 2020, 06:23:03 AM »
jeez, really guys?
« Reply #1252 on: November 09, 2020, 06:32:57 AM »
Offline Strawboss
« Reply #1253 on: November 09, 2020, 06:36:07 AM »
or a thinly veiled political pi$$ing contest.
« Reply #1254 on: November 09, 2020, 06:39:22 AM »
jeez, really guys?
Yes really. You got something else to do or someplace else to be? It's harmless, so why the negativity?
Offline Strawboss
« Reply #1256 on: November 09, 2020, 06:45:58 AM »
No negativity, just an observation, have fun kids.
« Reply #1257 on: November 09, 2020, 06:56:35 AM »
« Reply #1258 on: November 09, 2020, 04:37:52 PM »
Amerika's future national anthem...
https://youtu.be/-W4YetUHhKM
