Yeah, let's add more alcohol to the gas to attract even more water.
therein lies the simple problem....the addition of the substance is only one part of the equation.....
Happy Friday Everyone.
Got Slammed at work sooooo will dig into this more this weekend.
Had some Isoheat on hand and dumped that in. With only 5/6 miles on treatment no/little change.
IsoHeet does not magically dispell the water, it binds it up in the fuel solution, so it CAN be BURNED instead of sitting as globs in the tank.
It IS necessary to run the bike, under load, for some time, to burn the fuel up and effect the desired remedy.
Other than that, completely draing the tank, and the bowls, and using Fresh fuel from a NEW clean gascan, and adding the Isoheet, taking it for a 100 mile ride will complete the venture.
simply adding a substance of any kind, to the fuel, and allowing it to sit, will not do a thing.
I did give a link, that explained this.....
Q: How does HEET work?
A: HEET contains a special additive and
methanol. When HEET is added to the gas tank,
it sinks to the bottom and mixes with any water. Since both HEET and water are heavier than gasoline, they go to the bottom of the gas tank. HEET absorbs water and keeps it from freezing, and blocking the flow of gasoline through the gas line and fuel pump.
When the vehicle is started, the additives, methanol, water, and gasoline are consumed during combustion inside the engine.
Q: How does Iso-HEET work?
A: Iso-HEET contains isopropanol and special additives including Fuel Injector Cleaner. When Iso-HEET is added to the fuel tank, this formula remains in the solution with the gasoline,
and absorbs five times more than regular gas-line antifreeze. Any water in the gas tank mixes with the Iso-HEET, preventing the water from freezing in winter. Iso-HEET also removes water and condensation in warm, wet weather.
Then the entire mixture of gasoline, Iso-HEET and water are burned during combustion inside the engine. Iso-HEET cleans fuel injectors and carburetors for fast starts and smooth-running engines year round.
