Author Topic: Dyna-beads, anybody tried it ??  (Read 23370 times)
Offline att2008vn
  • Country: vn
  • C14 2010 ABS
« on: October 17, 2011, 08:58:46 AM »
Hi,
any feedback on this ??
I still feel something is not right in their video with the plastic bottle
at
Re: Dyna-beads, anybody tried it ??
« Reply #1 on: October 17, 2011, 09:21:43 AM »
Oh THIS topic again!?  ;D
« Reply #2 on: October 17, 2011, 10:01:27 AM »
 :popcorn:
« Reply #3 on: October 17, 2011, 10:05:48 AM »
AT,
What these guys are trying to say is that this topic has been DONE TO DEATH and if you'd do a search on it, you might get some info.
Offline att2008vn
  • Country: vn
  • C14 2010 ABS
« Reply #4 on: October 17, 2011, 10:11:10 AM »
thanks Conrad,
I got it after seeing the word "again" but then a search didn't give out much things here, i m searching on the other COG forum and found something, still reading there.  Anyway seems it doesn't fit me, the beads i mean, cuz of my habit of using the tire plugs.
Thanks
at
« Reply #5 on: October 17, 2011, 04:19:39 PM »
That is a great observation- tire plugs would no doubt interfere with the proper operation of those beads. See, brand new information in a new thread about an old subject. Good stuff.
Disclaimer: my post assumes that Dyna beads are even capable of "proper operation" under any circumstances. I know there are those who love to hate that product but I really do not have an opinion about Dyna beads other than being impressed with their ability to rile up the natives on the 'Net.  ;D
thanks Conrad,
Thanks
at
« Reply #6 on: October 17, 2011, 05:06:21 PM »
thanks Conrad,
Thanks
at
I think that both would be painful....
« Reply #7 on: October 17, 2011, 05:10:13 PM »
Man. the learning curve here has to be tough on newbies. :)
« Reply #8 on: October 17, 2011, 05:16:11 PM »
Any conversation concerning "beads" tends to make my wife a bit uneasy.
« Reply #9 on: October 17, 2011, 05:45:40 PM »
They gotta learn sometime...  Anything they say can be and will be used against them in a humorous way.
Any yes, Poke's wife does get nervous about any conversations about beads.
Offline lt1
  • 2008 C14
« Reply #10 on: October 17, 2011, 08:23:29 PM »
Perhaps you mean that there is no doubt in your opinion...  Personally, I do doubt that a tire plug would significantly interfere with the proper operation of the beads.  A few would probably stick to the plug at first, but the remainder would continue to operate "normally", however that may be perceived.
Eyes, Brain, Hands.  Repeat.
« Reply #11 on: October 17, 2011, 08:26:46 PM »
Tire plugs are a another great topic!  :D
« Reply #12 on: October 17, 2011, 08:34:14 PM »
Of course the 'in my opinion' is implied, just as it is when you post about those beads, right Clyde?  ;)
That said, I believe the beads must be free to move about inside the tire, and the stalk of a tire plug sticking up (or is that down?) into a tire carcass has to impede the beads' movement. I will not go so far to say that I think a tire plug would outright defeat the operation of the beads, just that a tire plug would have some effect on their operation. Assuming of course that the balancing beads work at all (easy there Clyde, just pulling on your chain a bit  ;)).
« Reply #13 on: October 17, 2011, 08:34:50 PM »
Yeah, but how soon can you use a synthetic tire plug on a new tire?
Offline lt1
  • 2008 C14
« Reply #14 on: October 17, 2011, 08:43:19 PM »
Actually, with DynaBeads, the correct phrase would be "in my experience".  I fortunately have no experience with the combination of beads and plugs, so yes, that part is "in my opinion".   Somehow, "no doubt" did not trigger the obviously implied "in my opinion" you mention.  My reading skills must be slipping.
Your other misapprehension is that the beads are continually rolling around the tire.  Once the bike/tire is up to speed, they are for the most part stable in their location.  Since the plug slightly alters the balance point of the wheel/tire, the beads' location will likely shift somewhat from the pre-puncture pattern.
Cheers.
« Reply #15 on: October 17, 2011, 08:57:10 PM »
No, I made no such assumption. The assumption I did (and continue) to make is that the beads must be free to <reach> whatever relative position they [for lack of a better word] 'should' be in after the tire accelerates. That is when I believe the plug tail will get in the way- while the beads are traveling, not necessarily when they are static (assuming they do reach equilibrium and tend to stay in one place after the tire is accelerated to speed).
Just as an aside Clyde, it seems that sometimes you get a bit defensive when no defense is necessary. I was not attacking you, Dyna beads or anything else. In fact, I actually like you Clyde although I do think that occasionally you could reach behind you and pull that stick out just a little bit (not all the way because that stick is part of your charm). This is a great forum and I like participating here, and I like reading your participation too. But occasionally you seem a little sensitive. And believe me, I am aware of your language and behavior preferences and already take them into consideration, in addition to many other things, when I do post. So please consider that we may really all be on the same side, more or less.
<snip>
Cheers.
« Reply #16 on: October 17, 2011, 09:02:42 PM »
 :-X
« Reply #17 on: October 17, 2011, 09:18:59 PM »
These guys will help you with your Dyno Bead issues, give 'em a call
Offline lt1
  • 2008 C14
« Reply #18 on: October 17, 2011, 10:36:11 PM »
I like you, too, Brian.  Even if you have a know-it-all attitude that is often unjustified.  A rope plug in a tire no more inhibits the flow of the dynabeads than a twig inhibits the flow of a river.  Of course, there may be a small delay or diversion, but the twig will not dam the river.  If you had 40 or 50 rope plugs in a tire, dynabeads would probably not work well.
Again, you seem not to grasp the concept of what the beads do and do not do within the tire.   Not that it is a big deal.  Perhaps trying to correct a misconception on the internet is a loser's game.  Perhaps even a sensitive loser's game.
Your turn.
« Reply #19 on: October 18, 2011, 12:58:36 AM »
When the wheel is in a static/constant motion I feel safe that they will find their home.  What happens to those beads during mild to hard braking?  What happens to them on irregular roads?  Add in plugs and everything changes, which of course should include the TPS.  Machine testing in a controlled environment will not replicate what we get on the street.  Finding that light spot and fixing a permanent weight removes the variables you have with free floating beads,  I wonder, do MX riders use these?
