Author Topic: Float Bowl Overflow Tubes Question  (Read 11233 times)
Offline mach1charlie
  • Lone Wolf... No Club
Re: Float Bowl Overflow Tubes Question
« Reply #20 on: October 26, 2011, 09:49:55 PM »
Green loctite will fix a loose press fit, and gas will not eat it. Red will work with gas also.
Charlie
Offline WiConnie
« Reply #21 on: October 27, 2011, 06:34:54 AM »
Since we're talking about fuel I found this interesting
http://www.americanmotorcyclist.com/news/11-10-14/AMA_supports_congressional_effort_for_more_study_of_ethanol-blended_fuel.aspx
The American Motorcyclist Association (AMA) applauds U.S. Rep. Jim Sensenbrenner (R-Wis.) for introducing a bill that calls for new research into the effects of certain ethanol-blended gasoline...........................................
New to me 97
Germantown, WI
Offline syntor
« Reply #22 on: October 27, 2011, 06:37:53 AM »
Dunno about green goop, I use el-cheapo 2-part-poxy with no problems. And if you make the toobs too short the fuel does indeed flow over whenever you hit a pothole. The road builders around here are particularly skilled at bumps and potholes, so I'm gunna pull the carbs and make up some longer toobs. Since those Wallies won't fix the roads.
Made up a steel sleve out of a 2 inch piece of Falcon fuel line and use that as a sort of a "crimp tool" and put it over the toob and beat it with a hammer. That basically "crimps" the toob in the hole and it doesn't move. Sort of like a press fit if you don't have a press.
No doubt SISF has a better jig for doing it, and yawl should just send your carb bowls to him. ;)
Offline WiConnie
« Reply #23 on: October 27, 2011, 05:53:11 PM »
Seal-All seems to be holding up after 24 hours....dumped the gas out of the bowl and took a look at the product...still flexible and showed no signs of degradation..added a second coat....I'll fill bowl again when it's set up and then will let sit for another 72 hours.
Game 6 is just about to start...Miller time :)
New to me 97
Germantown, WI
Offline conando
« Reply #24 on: November 01, 2011, 03:52:10 PM »
It's a donut, a JB Weld donut.
Fortunately, I press fit the tubes in as well, and the JB Weld was for good measure. I did it before we figured out that the JB Weld wouldn't work.
Offline SteveJ.
« Reply #25 on: November 01, 2011, 05:28:17 PM »
Awww. Ain't that a cute wittle donut.
America's Seaplane City
Offline Daytona_Mike
« Reply #26 on: November 01, 2011, 09:00:00 PM »
I do know what does work really well is Pro-Seal. I too did my  over flow tubes and the JB weld failed but I did a press fit so it did not matter.
Pro-seal is made for airplane tanks but I have tested on tanks with that use ethanol and it does work .
Offline kzz1king
« Reply #27 on: November 02, 2011, 03:52:35 PM »
Do you know which particular pro seal product Mike?
Wayne
2010 CONCOURS
1974 Z-1
Offline RFH87_Connie
« Reply #29 on: November 03, 2011, 06:53:55 AM »
At $83 per pint, i'd just send them to SISF.
Offline Steve in Sunny Fla
    • Shoodaben Engineering
« Reply #30 on: November 03, 2011, 07:08:34 AM »
  I also build and provide the drain tube system with each set, along with all instructions on layout, etc... Steve
Offline vinny
« Reply #31 on: November 03, 2011, 12:53:30 PM »
I dont see why Kawasaki stopped putting these tubes in their carb bowls?
My 1980's Z750 ltd had them in.
« Reply #32 on: November 03, 2011, 01:05:49 PM »
Probably an EPA (or some other agency) mandate I would think.  With them, gas can pour straight to the ground.
Offline vinny
« Reply #33 on: November 03, 2011, 01:38:47 PM »
Well at least that was one rule change that does make some sort of sense!
« Reply #34 on: November 03, 2011, 01:45:36 PM »
Actually, the Kawasaki 1200 voyagers have the same bowls WITH the overflows, all models from 86 to 03. that model has a fuel pump, so I figure that the overflows are in case of a fuel pump failing on. . On the connie, I expect the factory figured that since it had a vacuum operated percock, that should prevent any overflowing. steve
Offline vinny
« Reply #35 on: November 03, 2011, 01:58:35 PM »
Steve, did the overflows re-route back to the gas tank?
That would seem to be a sensible precaution for a  fuel pump ON failure situation, rather than just venting it
The vac gas tap was probably seen as a great idea when new. But as time goes by and rubber hardens / perishes it becomes a less attractive proposition!
Offline Gitbox
« Reply #36 on: November 13, 2011, 07:08:15 PM »
I guess I must be a glutton for punishment. I drilled and tapped the bowl, threaded some thick wall aluminum tube and torqued it in with red Loctite. If I had to do it over again, I'd send them to SISF.
2008 Yamaha FJR1300A
2004 Yamaha FJR1300 (sold)
