Author Topic: Throttle cable Lube  (Read 4694 times)
Offline Texanrider
  • There's no excuse for what I am about to do...
Throttle cable Lube
« on: May 16, 2011, 12:58:12 PM »
Does anyone know the best way to lube the throttle cable? I am not sure when, if ever has this been done on my bike since I bought it used. Any idea of how difficult a procedure this is?
09 Boulevard C50
95 Kawasaki Concours
Re: Throttle cable Lube
« Reply #1 on: May 16, 2011, 06:57:55 PM »
Pretty rare that anyone still does this today; the cables are lined with a teflon or nylon base and really don't need any lube.
YoDoc
« Reply #2 on: May 16, 2011, 08:28:24 PM »
This is true. There are special tools to do it (pressure cable luber) you can use WD-40 with the straw. More than likely though, what you really need to do is remove the throttle, and scotch brite the actual bar that the throttle sleeve rotates around. Also, the return spring cable is routed funny though the switch housing on that side. Lube that maybe?
Offline Texanrider
« Reply #3 on: May 16, 2011, 09:20:42 PM »
T Cro,
You may be right, but my Connie is a 95 and I am not sure if the PO ever lubed the cables or if he ever changed the cables for the new ones. Not sure if I should lube the cables or change them. I'm at a predicament.
09 Boulevard C50
« Reply #4 on: May 16, 2011, 09:27:45 PM »
I may not have been clear my point was that these cables really do not need lubing unless they are dragging badly and you need to free them up until replacements can be found; lubing cables is a thing of the past from our days of youth on dirt-bikes.
YoDoc
« Reply #5 on: May 16, 2011, 10:02:36 PM »
My 2003 has instructions for lubing the cables in the OMan.
Offline Texanrider
« Reply #6 on: May 16, 2011, 10:08:52 PM »
I don't even have the Oman! Lol
09 Boulevard C50
YoDoc
« Reply #7 on: May 16, 2011, 10:11:19 PM »
Yeah, the PO told me he didn't have it, but when I took the seat off to clean and inspect my *new* bike, I found it wedged up under the rear cowling, in a plastic bag from the Jurassic era.
Offline Cholla
« Reply #8 on: May 17, 2011, 05:30:24 AM »
In fact if the cables are Teflon lined lubing them degrades the lining.
