Author Topic: tips for front wheel bearing removal?  (Read 17073 times)
Offline Silver Connie
« on: September 05, 2011, 08:38:52 PM »
i cant get a screwdriver or pin punch to catch the lip of the bearing through the axle hole. any other tricks?  i hope i dont need a pilot bearing puller cuz mines broken.
Re: tips for front wheel bearing removal?
« Reply #1 on: September 05, 2011, 10:17:47 PM »
I use a tire iron cut off square and clean using an abrasive wheel, the edges must be sharp and square as shown in the photo
tool end that contacts bearing
slide it down untill it catches lip on bearing, then smack the punch sideways to displace the spacer, smack it a bunch of times, sideways in one spot and hold the punch
then, keeping pressure on the punch sideways in theat position, smack down hard on the end of the punch,
 repeat both sequences, untill you get the bearing to move, and then you can get to the lip easier.
if you are doing the front, start with the side opposite the speedo gear in the UP position, there is a bit more room knocking the speedo side bearing out as far as spacer tilt goes.
Offline gpzrocker
« Reply #2 on: September 06, 2011, 01:49:08 AM »
When I swallowed my pride and asked at a decent local shop, they took the wheel and $20 later I returned my useless bearing puller that cost much more.
Just a thought, and my results may not be typical.
Offline dude412
« Reply #3 on: September 06, 2011, 06:28:52 AM »
Amen brother! ;)
« Reply #4 on: September 06, 2011, 06:43:50 AM »
When it comes to removing wheel bearings there is absolutely no better tool than BRUTE FORCE and the heaviest punch that you can get yo grab the inner edge of the bearing; no namby pamby tapping will do here you've got to really hit the punch to get the job done.
Myself I use a heavy drift punch that I managed to bend ever so slightly to which this really helps it catch the inner bearing race.
Offline George R. Young
  • Moderator
    • Concours 2001 Farkles
« Reply #5 on: September 06, 2011, 07:36:01 AM »
There's a spacer tube between the bearings. If you haven't already, give it a crank sideways to expose the bearing lip.
Then bash with your favourite hammer and drift.
Offline RedWyvern
« Reply #6 on: September 06, 2011, 07:39:34 AM »
In case you didn't notice, there is a circlip on each bearing (one holds the speedo drive receiver).  I've seen one be missed.
If you enter from opposite the speedo drive side there is a bit of a whallowed out were you can push the drift more for bite than you can doing it from the other side.  You don't get much bite, so the drift will usually slip off with each (or so many) hits.
I bang them hard too, but I also keep working my drift around about 1/3d of the hole.  This way I'm not jamming my bearing by cocking it sideways, but working it 1/3d at a time partially out.
Pop the new bearings in the freezer so they go in easier.
I also grease the outer edge of mine.  Some have said this is not good, but ever since the first replacement, which were almost impossible to free up and get out, the next two changes almost hurt me as the bearing came out so easily (I didn't need the force).  I even had a friend come to help me the second time I hanged them, telling him it took me a lot of patience to get them out.  Bam, out one falls, and he laughed.  FWIW
Mark
Offline RedWyvern
« Reply #7 on: September 06, 2011, 07:41:51 AM »
Forgot to mention.  If you have a means, grind the inside of the spacer on each end so that it is sorta oval shaped in there.  The spacer is there for width, not axle, so the hole in it does not matter.  If you can get the oval like shape going it gives you a bit of a wide area to use if a next time comes about.
Mark
« Reply #8 on: September 06, 2011, 08:45:57 AM »
i like the idea of making a relief point on the spacer. ive seen that on other spacers. i did see the circlips and removed them. ill take the punch to the grinder and try to put a slight bow in it also.
Offline Summit670
« Reply #9 on: September 06, 2011, 12:39:54 PM »
If needed you can also insert some type of tool or dowel in the opposite side to help hold the punch end against the lip of the bearing.
Arctic Cat M8 163 rules
« Reply #10 on: September 06, 2011, 04:08:12 PM »
grinding special tools, bending punches, etc is a waste. the tool I described, is about as cheap as it can be, a chopped off tire iron. The instructions and sequence I showed above, allowed the person in the photos I shot, to effectivly remove the bearings..... that person happened to be my wife, who i got to assist me when I shot the instructions for the Concourier artical "Shake, Rattle, and Roll"...... if she could accomplish the job with those tools, anyone can. ::)
forget about buying a $20 tapered punch, the taper is actually a deficit in this tool/procedure, and does not allow the punch to be shifted correctly to force the spacer sideways when struck to offset it.
as Tony noted, light wristed tappy-tapping will not suffice, you have to smack the thing, both sideways to offset the spacer, and then downwards to dislodge the bearing..
Offline rcannon409
« Reply #11 on: September 06, 2011, 05:12:06 PM »
I've used my dremel cut off wheel after the shop left the outer race in place.   BUT, just as important, did you find a way to get the new bearings in place without damage?  I've found my dirtbike bearings will last much longer if I am able to use as little force as possible to seat them.
My go to anymore is to heat the hub with a propane torch and cool the bearing with dry ice.  It will usually fall into place without using anything. I do have a plastic punch that will help as long as the temp difference is there.
« Reply #12 on: September 06, 2011, 05:19:36 PM »
thanks for the pics but i cant view them on my phone. i dont have a computer.  i had a five dollar set of chinese roll pin punches i used one to fashion a tappered edge on then hardened it by heating with torch and quenching it. then i got the bfh out and went to work. jobs done wheels back on and youre not going to believe this; i managed to get the tire off and new one on the rim with wheel weights left on it, lined up the balance mark with the air valve, runs out fine. no wobble at any speed or with no hands. one in a million. ill keep an eye on tread wear.  i have some shot i can put in and take the weights off if things go awry. this thing rides like a new bike. funny how you get used to the irregularities of a bad tire then get a good one and notice how much better it is.  thanks again for the help.
Offline RedWyvern
« Reply #13 on: September 06, 2011, 07:20:01 PM »
Good to hear you made it work.
Nice wording on the old to new tire.  I shake my head when someone says "I put on the new XX and they are so much better than YY, I'll never use those again".  I'll ask, "You remember how the YY felt when you put it on?"  The answer... "No, but they are so different than the new one feels".
uh, DUH.  Ok, I'll be nice... "I hope a brand new tire feels better than a worn out one" ;)
Mark
Offline KenE
« Reply #14 on: September 06, 2011, 11:16:41 PM »
I lucked into a method...
I was trying to hold a tapered punch in place against the bearing edge, with a large tapered cold chisel from the outer side. A couple of whacks later, of course it slipped off the bearing, wedging itself HARD against the cold chisel,  I smacked it again in anger,  AND STARTED THE BEARING OUT. Yippee! A few smacks later I was at the vise hammering the old bearing off the 2 wedged in tapered chisels. Worked well.
I then filed a rebate on the inside of the center spacer to allow room for a punch= easy removal next time. (I think credit  goes to man of blues for the rebate idea...)
Regards,
KenE
Offline Strawboss
« Reply #15 on: September 07, 2011, 06:38:52 AM »
I think saving money is good but saving time is somtimes better if it doesn't cost all that much. I'm suprised nobody mentioned a commercial bearing puller. It took me all of about 30 seconds to pull my bearings with no toil, brute force, swearing, or scraped knuckles. OK, $50 may be a bit much for some, but it will last forever, and it comes with many different sizes.
http://pitposse.com/whbereset.html
« Reply #16 on: September 07, 2011, 05:36:55 PM »
Regards,
KenE
Yeah, i printed the part about cutting a relief notch in the artical...
I have to say you stumbled onto sumthin there when you explain the 2 chisels and what occured......me like that, as soon as you said that I got the mental picture of what took place, and it sounds interesting.... I may give that method a test out on a spare rim I have, and report back on it...really does sound simple and effective......even an old phart like me learns things sometimes, and that sounds like a keeper!!!! ;)  I wish I'da thunk that one up!! :thumbs: :thumbs: :goodpost: :thumbs:
Offline Gitbox
« Reply #17 on: September 18, 2011, 05:10:12 PM »
Go to your local Autozone and borrow a blind bearing puller. It's free and makes the job super easy.
2008 Yamaha FJR1300A
2004 Yamaha FJR1300 (sold)
Offline T. Kessler
« Reply #18 on: June 02, 2013, 02:38:58 PM »
You have instructed is on those capture. I have understand your prospective. And i am forgetting to bye $20 tapered punch.
« Last Edit: June 03, 2013, 01:42:37 AM by T. Kessler »
« Reply #19 on: June 03, 2013, 09:22:08 AM »
The first time, struggle, bend several implements, swear lots and generally get stressed and huffy.
However, one the bearings are out, take the central spacer tube and cut a Slot in one end with an angle grinder.
Clean up the edges and refit with new bearings.
The next time ya come to change bearings there is a nice slot that lets you get purchase on the inner race and you can hammer the bearing out.
Personally I cut a slot across both sides of each end of the spacer.
