Author Topic: The Buzz  (Read 8005 times)
Offline throb
The Buzz
« on: July 15, 2011, 04:10:33 AM »
  In the seemingly never ending quest to modify and improve, my next mod will be to fill the handlebars (starting with the left since it's the worst, just to see if it makes any difference) with #9 lead shot to decrease the buzz in the 4k rpm range.  Anyone happen to know how much shot is needed?
Offline throb
Re: The Buzz
« Reply #1 on: July 15, 2011, 07:25:41 PM »
If anyone is interested, the magic number is approximately 10oz of shot per side.   :thumbs:
Offline gpzrocker
Re: The Buzz
« Reply #2 on: July 16, 2011, 06:08:50 AM »
If that does not work, I have had great success changing the front wheel bearing.
Offline Pfloydgad
Re: The Buzz
« Reply #3 on: July 16, 2011, 07:35:42 AM »
Front Fork brace and Murphs Bar End weights will do wonders also. And the fork brace will improve handeling also. JMHO.
Good luck and ride safe.
Greg
Offline Lodogg2221
Re: The Buzz
« Reply #4 on: July 16, 2011, 09:12:48 PM »
So did the #9 help?
Say what?
Offline Cybercraig
    • Sprayboy-Services
Re: The Buzz
« Reply #5 on: July 18, 2011, 12:34:13 PM »
NO, DON"T USE #9!!!! There is a weep hole on the throttle side that #9 can slip through and cause the twist throttle to grind or even jam. Use #6 or #4 as they are too big to fit in the hole. Ask me how I found this out.  :yikes:
'98 becoming more farkled up by the minute.
R.I.P. Steve Earl  "Mr. FJR"
Re: The Buzz
« Reply #6 on: July 18, 2011, 01:35:27 PM »
Just plug the hole with some stiff wax and/or some elec tape. I never felt the need with my bike but if I did I would have melted the lead and poured them solid as I think it would really help to "weight" down the vibes.
Offline Nosmo
Re: The Buzz
« Reply #7 on: July 18, 2011, 07:44:43 PM »
I had some plastic tubes that fit well inside the bars, and put some "bird shot" in them, (not sure what gauge number), sealed the ends with electrical tape, and slipped this "cartridge" into the bars.  I didn't fill it totally full, my theory being let the shot sort of vibrate around and resonate or whatever.  I never had much buzz to start with but it seemed to help.  I think I got more results out of reshimming and torquing the engine mount bolts.  Also I have the heavy-type Throttlemeisters.  What I don't seem to have now is buzz.  Whatever works for you.
Re: The Buzz
« Reply #8 on: July 18, 2011, 08:04:42 PM »
If bars are not filled to 101 % full packed solid you can make matters worse; you want to stop the bars from ringing nor do you want anything inside ringing either. I'm with you on everything else including the Heavy ThrottleMeisters too.
Offline Nosmo
Re: The Buzz
« Reply #9 on: July 18, 2011, 08:15:31 PM »
Well, it was just a theory......I'd try pulling them out and do the pack-full style, but it's smooth enough right now I'm too lazy to mess with it.  Thanks, Tony.
Re: The Buzz
« Reply #10 on: July 18, 2011, 08:24:17 PM »
I hear ya there..... I've needed to clean the idle circuits on my carbs since last July! I just keep using the choke lever to smooth her out until I feel like doing the deed.
Offline hlh1
  • COG #548
Re: The Buzz
« Reply #11 on: July 22, 2011, 04:30:49 PM »
I've found the Genmar risers noticably increase the felt "buzz".
COG #548
My bikes:  Suzuki 06 WeeStrom, Kawasaki 09 C14 ABS, 83 Suzuki GS1100ED,
Offline throb
Re: The Buzz
« Reply #12 on: July 23, 2011, 04:10:32 AM »
So did the #9 help?
Yes it did.  Much less noticeable now.  It wasn't horrible before, but none the less, noticable.  And since it was the worst in the RPM range where I spend most of my riding time  :o  I wanted it reduced as much as possible.  This did the trick.
Offline throb
Re: The Buzz
« Reply #13 on: July 23, 2011, 04:14:41 AM »
  Where is this weep hole of which you speak?  I had my grips off earlier this year, but truthfully never paid attention for any holes.  The only one I know of is the threaded hole on the end of the bar which the bolt that holds the end weight threads into.
Offline throb
Re: The Buzz
« Reply #14 on: July 23, 2011, 04:22:01 AM »
   :thumbs: on the fork brace.  I have that on (from Murph), but in lieu of spending the $$ on the bar end weights I wanted to try this first since it would be a more frugal approach and that's just more $ for  :chugbeer:!
  The weights would look cooler, but probably the only thing much different is the 10 minutes more per side it took to remove the bar to hold it upright while funneling the shot inside.
Offline ATC Buckeye
Re: The Buzz
« Reply #15 on: July 23, 2011, 06:46:12 AM »
The only hole I noticed was the one that the little peg on the switchgear goes into to keep the switchgear from twisting around the bar.  So if the switchgear is in place, no buckshot coming through that hole.
I have also done the lead buckshot, and it helps I think.  I've done it on my last several 4 cylinder bikes.
Offline jim snyder
Re: The Buzz
« Reply #16 on: July 23, 2011, 09:36:48 PM »
Getting rid of the "tuning fork" handlebars and converting to standard 7/8" did the trick for me. A KB bar adaptor and a set of $15 Bikemaster Daytona GP bars. Just saying in case the shot thing doesn't work out.
Offline jim snyder
Re: The Buzz
« Reply #17 on: July 23, 2011, 09:40:38 PM »
The reason for this is it increases the "tuning fork" affect of the stock bars. The longer the tuning fork sections are the more vibration they can make. I had the same problem when I added the GenMars to my stock bars. I couldn't ride 50 miles without my hands going numb. After switching to the standard 7/8" handlebars I can ride 250 miles with no problem.
Offline throb
Re: The Buzz
« Reply #18 on: July 24, 2011, 04:03:49 AM »
  The shot decreased the vibration quite a lot.  There is still some buzz, (but what inline 4 doesn't have) but nothing even close to what it was like before.  It was time and money well spent.
  What type of handlebar are you using, or is there anyone out there who has converted to regular bars have recommendations/knowledge what bar(s) are close to the same angle/setback, etc as the OE bars with risers?  It may be a mod looked at in the future.
  Jim, I also see in your web photos you have setback plates on your Connie.  How much closer do they bring the bars to you?
Offline hlh1
  • COG #548
Re: The Buzz
« Reply #19 on: July 24, 2011, 07:17:21 AM »
Where did you find the KB bar adaptor?
COG #548
