Welcome,
Guest
. Please
login
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Search
Calendar
Login
The C10, aka Kawasaki Concours - The Original
The Bike - C10
(Moderator:
George R. Young
01 zg1000 choke issue
« previous
next »
Print
Go Down
Author
Topic: 01 zg1000 choke issue (Read 1906 times)
Jjc331
Newbie
on:
January 05, 2022, 04:58:41 PM »
Hi, I’ve got a 2001 concours that I fixed up. I bought new needles and bowl gaskets for the carbs. I cleaned them very well. Removed everything and cleaned all the passages including the choke plungers. I checked all the passages. I’ve been through the carbs several times. If the air is fairly warm(70f)it will start with a bit of effort but once it warms up it runs amazing. The problem is the choke doesn’t work. I grew up working in motorcycle shops and have rebuilt lots of carbs. I’ve never had a problem like this before. Idk maybe someone here might having something insightful to say. Thanks.
Logged
Boomer
Full Member
Country:
Re: 01 zg1000 choke issue
Reply #1 on:
January 06, 2022, 01:31:01 AM »
On the C10 carbs it is a Fuel Enrichment system, it is not a choke.
A choke restricts airflow to make the fuel-air mix richer.
The system fitted to the C10s Keihin carbs adds extra fuel instead.
If pulling the lever pulls the 4 plungers open but makes no difference then you either have a blockage in the fuel supply to the plungers or else the carbs are already running too rich and opening the plungers is supplying too much fuel.
Also make certain that upon closing the "choke" all 4 plungers go back into the carb.
I saw one set a few years back where the return springs were so weak that the plungers stayed open.
Logged
connie_rider
Sr. Member
Reply #2 on:
January 06, 2022, 10:32:11 AM »
In the bowl area near the top, there is a hole below each of the Enrichmemnt valves.
I had the same problem you're describing, and it turned out that one {or more} of those holes was stopped up.
Logged
Print
Go Up
« previous
next »
The Bike - C10
(Moderator:
George R. Young
