Author Topic: C10 Front End  (Read 2087 times)
Offline sport rider
C10 Front End
« on: September 23, 2021, 03:17:53 PM »
I am converting my sidecar rig C10 back to "normal".  that means I'm removing my leading link front end.  I need forks, brake calipers, wheel, axles, speedo housing.  Anyone have anything?  closer to NC would be better so that I couid save on shipping.
Offline Stasch
Re: C10 Front End
« Reply #1 on: September 23, 2021, 05:28:43 PM »
I have some stuff.  Is your C10 86-93 or 94-06?
Offline sport rider
Re: C10 Front End
« Reply #2 on: September 23, 2021, 07:14:39 PM »
should have mentioned that, huh.  duh
it's a 94.
Offline Stasch
Re: C10 Front End
« Reply #3 on: September 24, 2021, 07:20:16 AM »
I'm in MI so shipping would be necessary but I can usually find efficient ways to do that.
I have everything EXCEPT the front wheel.
From a 1999 with 65,183 miles parted out due to hydrolock and  horrible engine knock.
Fork tube set
Front Brake set with everything EXCEPT the brake lever
    Included: MC, lines, calipers, fork brackets etc.,
Front axle assembly - Box 107 (Midland 99)
speedo housing - Box 107 (Midland 99)
If you need front rotors, I also have a set from this bike that ran smooth when I briefly rode the bike around the neighborhood before parting.
They have some surface rust, would need a soak in apple vinegar or Vapo-Rust.
Offline sport rider
Re: C10 Front End
« Reply #4 on: September 24, 2021, 08:05:39 AM »
I have a lead on something local but will reach out if that doesn't work.  thanks!!!
