Author Topic: 2008 Neutron Silver C14  (Read 724 times)
Offline robertv
  • 2008 C14 Silver
« on: June 23, 2021, 04:36:42 PM »
Up for sale is my 2008 Neutron Silver color C14 non-ABS. Mileage at ~89,500; will go up as I'm still using this. Recently changed oil after COG longest day ride including new PR4 tires!
Downtime from pandemic last year so did 1- valves, 2- changed radiator hoses (Samco) with coolant flush and added R&G radiator guard, 3- upgraded suspension Traxxion AK20 and Penske 8983 double.
  • ECU flash - SiSF Mountain Runner Premium
  • Canyon cages
  • Delkevic slip-on
  • Heated grips
  • V-stream windshield
  • Projekt D aerowing/handguard/wind deflector, tinted
  • MM10 LEDs under mirrors
  • LEDs in the front headlights
  • RAM X-grip for phone on reservoir; RAM ball base on brake & clutch reservoir bracket
  • Dual USB socket on left; USB-C PD w/voltage meter on right
  • Techmount for GPS
  • Kawasaki(Givi) case 47L mounted on a SW-Motech steel rack
  • Techspec snake skin tank pads
  • Bearing shifter
  • Eastern beaver fuse block for LEDs and heated grips
  • Seth Laam seat
  • Front fender extender
  • Keyless gas cap
  • Brake/clutch fluid maintenance done back in March
  • KiPASS bypass mod by BDF
  • push button mod to rotate view thru dash display
  • Both FOBs!
$4500, PM if interested! Still rides fantastic and fast. Clean title.
