Author Topic: backfiring?  (Read 3645 times)
Offline jim-d
backfiring?
« on: August 18, 2020, 06:34:17 PM »
what would cause a 2002 c-10
to backfire thrrough the exhaust?  it is imtermittent and not when pulling out.  more gliding to a stop.  bike was running a little funky then started backfirig. but the engine smoothed out.
had the carbs rebuilt in August.  then the bike ran great.  sat for a month and started acting up.
Re: backfiring?
« Reply #1 on: August 19, 2020, 03:19:23 AM »
If it is when you have the throttle shut, it's probably an exhaust leak.
Somewhere the exhaust is letting fresh air in and the un-burned or part-burned fuel is igniting in the exhaust.
So, either you are running very rich and still have the PAIR valves fitted, or you have a leak in your exhaust.
Check the balance pipe, where the headers bolt to the engine, and where the muffler attaches to the header.
Offline Chrome Megaphone
Re: backfiring?
« Reply #2 on: August 19, 2020, 08:34:49 AM »
I thought popping on overrun was lean?
http://www.mikuni.com/tg_backfires_in_exhaust.html
If no exhaust leaks maybe there's still junk in the carbs, Check the intake boots by spraying carb cleaner and listen for RPM changes.
Re: backfiring?
« Reply #3 on: August 19, 2020, 10:31:41 AM »
Could also be sitting for a month and something got gummed up.  Something I don't experience anymore with FI.
Re: backfiring?
« Reply #4 on: August 19, 2020, 10:46:36 AM »
If you paid for the carb job take it back.  I would. If the tech didn't soak them long enough and chase the passages with a strand of throttle cable before blowing them out he didn't do it right.
Re: backfiring?
« Reply #5 on: August 19, 2020, 10:49:58 AM »
Last August?  Sat through the winter?
Offline DC Concours
  • 2001 Concours, ~35K miles
Re: backfiring?
« Reply #6 on: August 19, 2020, 11:00:27 AM »
I haven't had carbs cause backfiring issues after a long storage period. Just hiccups and low speed rpm issues. Redo the carbs after you eliminate any exhaust problems.
Offline Daytona_Mike
Re: backfiring?
« Reply #7 on: August 19, 2020, 03:47:57 PM »
One month??... I have had jets blocked from sitting 3 weeks. You may have to dump that fuel ..drain the bowls... and try fresh fuel. Are you adding  a capfull of two stroke oil to each tank of gas? Stabilizer?  Anything? Ethanol free fuel?
Offline jim-d
Re: backfiring?
« Reply #8 on: August 20, 2020, 12:56:26 PM »
I'm done with this bike.  I believe it was severely damaged by leaking carbs.
When I got the carbs back it ran like a top, that was May.
last week I started it up, there was a decided thump, like one cylinder wasn't firing.  made a mental note
last night started it again & things got ugly.  Started backfiring, the thump went away but I stopped for gas & it wouldn't start and run without the enricher on full.  No power in the throttle.   There was a metallic ping when it ran.
So I am tired of this machine and an offering it to anybody who wants it for free.  I live in Marlton NJ, come get it.
If transportation is a problem I will gladly get the sawzall and chop it up into manageable parts for you.
Call me, come get it.
Re: backfiring?
« Reply #9 on: August 20, 2020, 01:44:57 PM »
Why are all these free bikes always in the NE? :(
Offline DC Concours
Re: backfiring?
« Reply #10 on: August 20, 2020, 04:22:42 PM »
Who did your carbs? Were overflow installed? You may have a bent rod.
Don't throw away your bike. It still have lots of valuable parts on it.
gpineau
Re: backfiring?
« Reply #11 on: August 20, 2020, 04:41:11 PM »
If I lived in NJ I would take you up on it. Lots of good parts still on it. I'm in colorado so I cant.
Offline DC Concours
Re: backfiring?
« Reply #12 on: August 20, 2020, 04:45:07 PM »
Me too. If I had a truck i would drive to him. Damn.
Offline jim-d
Re: backfiring?
« Reply #13 on: August 20, 2020, 05:01:11 PM »
carbs were done by popular person on this board.  thought i was home free.  valve is on run and been leaking for 2 days. nowthe neighbor is complaining about the smell.  i have just had enough.
gpineau
Re: backfiring?
« Reply #14 on: August 20, 2020, 07:18:27 PM »
So do you think you hydro-locked and bent a rod ?
Bummer.
Re: backfiring?
« Reply #15 on: August 20, 2020, 08:10:34 PM »
  SO... do you know if  this popular person did  install OverFlow tubes??  I hope?
Re: backfiring?
« Reply #16 on: August 21, 2020, 10:29:23 AM »
:popcorn: lol
Re: backfiring?
« Reply #17 on: August 21, 2020, 02:46:52 PM »
Maybe O/T but isn't it better to have hydrolock than a garage fire?
Offline DC Concours
Re: backfiring?
« Reply #18 on: August 21, 2020, 10:37:39 PM »
Did Steve from Fla do your carbs and were overflow tubes installed?
Offline jim-d
Re: backfiring?
« Reply #19 on: August 24, 2020, 07:48:27 AM »
yes I think I did.
Putting htis thing on craig's list today.
LAST CHANCE!!!
Going shopping tonight on the list
Yamaha MT 07  2 cylinder 650
Kawasaki W 800 2 cylinder air cooled classic just like my college days
Yamaha Bolt.  Sportster like air cooled 650
Back to basics, no motor bloat for this guy.
I like the Honda CB650F but it's heavy & 4 cylinders.  I think I'm cured!
I want something 400lbs or less that is simple to take care of.
« Last Edit: August 24, 2020, 08:21:55 AM by jim-d »
