Author Topic: Rear brake not working  (Read 8881 times)
Offline basmntdweller
    • The Profile Brotherhood
« on: April 08, 2020, 03:24:45 PM »
Not been on here for several years but I’ve been riding a bit.
The last couple years I’ve hardly logged any miles for various reasons. I had noticed that if I hadn’t rode for a while, the rear brake pedal didn’t hardly move. I’d put lots of pressure on it and it would sorta work. Now I can really stand on the rear brake but it doesn’t move. I figured it was either the pedal cylinder or the caliper rusted or just plain stuck. Today I had a minute so I barely loosened the banjo bolt on the cylinder and the pedal worked and pushed a bit of fluid out. I figure the cylinder is okay. Next I went to the line on the caliper. Loosened a bit but pedal is rock solid and no fluid came out. Now I’m guessing there is a problem in some part of the ABS system. I know virtually nothing about ABS systems but not much I can’t take apart and get reassembled. I still assume there’s something rusted or stuck, just in the ABS valves. Can anyone shed any light on this, maybe give me some direction?
Thanks, Matt
'09 C14
'98 DR-350
'03 Honda CBR600RR track bike
Re: Rear brake not working
« Reply #1 on: April 08, 2020, 03:27:20 PM »
Might start looking for a pump on ebay.
« Reply #2 on: April 08, 2020, 03:44:52 PM »
Pump???
'09 C14
'98 DR-350
« Reply #3 on: April 08, 2020, 04:46:15 PM »
ABS pump
« Reply #4 on: April 08, 2020, 06:13:33 PM »
Yep.  This can be caused by a rear master cylinder or a rock caught in the rear brake lever assembly (recall for that one).
« Reply #5 on: April 08, 2020, 06:24:39 PM »
The rear master cylinder seems fine. It’s sending pressure to the abs unit but not passing it to the caliper.
I will have a good look for rocks though.
Matt
'09 C14
'98 DR-350
« Reply #6 on: April 08, 2020, 07:34:23 PM »
Well, if it ain't a rock, like Gary said it's the ABS unit unfortunately.
