Author Topic: Bleeding clutch 2011 c14  (Read 14491 times)
Offline Silverbullet65
« on: February 16, 2019, 09:21:26 AM »
I’m watching Fred Harmon’s video
On bleeding the brakes and clutch
On a 2011 c14 and the clutch bleeding
Is not the same on a 2011...
I cannot find the nipple?
Not the first time😜 heehee
Safety is no accident
Re: Bleeding clutch 2011 c14
« Reply #1 on: February 16, 2019, 11:05:07 AM »
On a 2008 c14 and the clutch bleeding
I can't help you with your nipple finding problem (I'd be in trouble if I asked you if you're looking for hair around it right?  :-X)
...anyway back to the clutch..you need to remove the left lower fairing, I believe it's removal is described on disc 10. According to the shop manual the lower fairing can be removed by itself, however I thing Fred's video shows the removal of the middle fairing above it first so that would make it more difficult to follow.
« Reply #2 on: February 16, 2019, 12:15:30 PM »
Too late, you're in trouble.
« Reply #3 on: February 16, 2019, 05:07:51 PM »
Nice!
« Reply #4 on: February 16, 2019, 05:53:17 PM »
By the way,
Bleeding the rear brake I accidentally
Let the reservoir empty and got air in the
Rear line...I continued bleeding but there’s still some air
In there I rode it and seemed fine
Thoughts??
Offline Rubber_Snake
  • 2009 GTR1400 ABS, Black
« Reply #5 on: February 16, 2019, 05:57:55 PM »
By the way,
Thoughts??
Bleed the rear brakes completely to remove all of the air.  Otherwise, as the brakes heat up, you may lose some braking ability.
« Reply #6 on: February 16, 2019, 06:05:30 PM »
I bled them pretty thoroughly
But could still see small bubbles
Is that normal?
« Reply #7 on: February 16, 2019, 06:13:44 PM »
Where are you seeing bubbles?  In the tube that you’re bleeding out of or are you seeing bubbles in the glass “window” of the master cylinder?  If it’s in the glass window, that shouldn’t be a problem.
Sometimes, as you break open the bleeder “nipple”, air appears to escape, but oftentimes it’s air getting through the threads.  If that’s the case, you should be okay, but you want to keep an eye on it.  Just pay attention to the pedal action as the brakes heat up.  If the brake pedal ever feels spongy, you still have air in the system.
« Reply #8 on: February 16, 2019, 06:36:59 PM »
rear master cylinder.... glass window?
new one on me...
« Reply #9 on: February 16, 2019, 06:39:34 PM »
It’s very very small pin size bubbles in the tube coming from the lower
Rear master cylinder ...nipple😜
Two hour trip tomorrow should know more then
Great info
Thank you☘️
« Reply #10 on: February 16, 2019, 07:33:21 PM »
new one on me...
I thought there was one.  I’m guessing no...
Must’ve been thinking about my “other” bike...   :o
« Reply #11 on: February 16, 2019, 07:43:06 PM »
If you guys keep saying 'nipples', I'm going to have to ban someone...
« Reply #12 on: February 17, 2019, 03:55:41 AM »
Heehee
« Reply #13 on: February 17, 2019, 01:23:44 PM »
but.... you just said it....  :rotflmao:
https://youtu.be/uio1J2PKzLI
http://youtu.be/uio1J2PKzLI
https://www.dailymotion.com/video/x6978bu
but they are sooo useful for many things...
« Reply #14 on: February 18, 2019, 07:35:31 PM »
Funny 😆
So Marty my man!
Once again you are such a wonderful
Help...not only did I get to bleed the
Clutch hidden under the lower fairing
I didnt need to completely remove it..
Just removed the two snap rivets
3 bolts and two lower screws up front
and she moved far enough sideways
To get it done...I removed the GSG engine
Guards /frame sliders
to make it easier to bleed the clutch
and I decided Not to put them back on.
I’m gonna put Them up for sale
in the flea market
Really appreciate the help! Much obliged🙏
« Reply #15 on: February 19, 2019, 09:12:21 AM »
So Marty my man!
to make it easier to bleed the clutch....
I just love it when someone else does all the work and I get the credit.  8)  :)
