What is the location of the majority of your street riding motorcycle flats? (No Dirt Bike Flats)
I have never gotten a flat tire on a street bike
22 (31.4%)
I tend to Get flats equal in the front and rear tires
3 (4.3%)
I tend to Get more flats in the front tire
1 (1.4%)
I tend to Get more flats in the rear tire
23 (32.9%)
Most flats caused by hitting large debris in the road (Rocks, bottles, truck tires)
0 (0%)
Most flats caused by a leaky or failing valve stem or core
1 (1.4%)
Most flats caused by rider error (hitting a curb...)
0 (0%)
Most flats caused by nails or screws or staples
20 (28.6%)
Most flats caused by defective tire or tire installation or rim leak
0 (0%)
Total Members Voted: 49
Voting closed: July 16, 2011, 02:31:43 PM
Author Topic: Do you get it more often in the rear?  (Read 6788 times)
Offline CrashKLRtoConnie
« on: July 06, 2011, 02:31:43 PM »
Okay. I was hoping to confirm the published ratio of rear tire flats to front tire flats for street motorcycles. (from a very old Cycle Magazine)
Also if you can vote on what caused the most flats.
  <<<    ~ 1 front flat vs ~ 4 rear flats.     >>>
2008 C14 GTR1400 AKA "Connie"
Re: Do you get it more often in the rear?
« Reply #1 on: July 06, 2011, 02:40:42 PM »
Cant let this go-----I NEVER GET IT IN THE REAR 8)
I did get a staple once in the rear (tire of course) during the state IP course.  Filled 'er with air and rode her home.  Only flat to date, even includes car tires 8)  I never go cheap with rubber, known to cause troubles, be it babies or road rash!
Offline Timalan
    • www.thismotorcyclelife.net
« Reply #2 on: July 06, 2011, 02:53:01 PM »
I rode through a pot hole on my recent trip. bottomed out front forks crunch and then hit exhaust pipes under the bike and the connecting parts of the shock/swingarm... it hit so hard I though for sure I deflated the tires or bent a rim. Nope! wiping head and say shew... I was miles from nowhere. glad the tires and wheels held up. but, i did get a nail offroading the FJR in West Virginia. Good times.
Offline Strawboss
« Reply #3 on: July 06, 2011, 02:54:34 PM »
Equal front and rear, tires that is.
Offline sas mayhem
« Reply #4 on: July 06, 2011, 02:56:56 PM »
Nothing yet, knock on wood.
09 Connie
Offline Tom J.
  • "Disciples of Displacement" charter member
« Reply #5 on: July 06, 2011, 03:27:17 PM »
Nah, wife will have nothing to do with it-   ;)
'08 Kawasaki Concours
'98 Yamaha VMax
'84 Honda V65 Magna
'82 Honda CX500 Custom
Offline Glenn
  • 2011 Concours14, 1984 KZ1100R, 2008 KLR685
« Reply #6 on: July 06, 2011, 03:30:44 PM »
I've never had a front tire go flat. It is always the rear tire that goes flat. Every time it is debris, nails or screws that are the culprits. I've found that the newer the tire, the more likely hood of experiencing a flat! :'(
"Never trade the thrills of living for the security of existence."
« Reply #7 on: July 06, 2011, 03:35:48 PM »
Offline Cold Streak
« Reply #8 on: July 06, 2011, 03:38:01 PM »
I've only had one flat and it was a nail in the rear.  Luckily it was on the OE Bridgestone which was about ready to go anyway.  The other night I got home late after riding through the countryside.  The next morning I found a chunk of jagged steel sticking out of a tread block on the rear.  I pulled it out and was relieved to see it hadn't penetrated very far yet.
I think most flats occur in the rear because the front tire kicks up the debris, sending it cartwheeling along the road, then the rear comes along and runs it down.  If you are lucky the debris moves out of the way or is in a position where it can't stick into the tire.
Offline Tom J.
« Reply #9 on: July 06, 2011, 03:39:47 PM »
I'm sorry, was that a nail or a screw in the rear?
'98 Yamaha VMax
'84 Honda V65 Magna
« Reply #10 on: July 06, 2011, 03:52:48 PM »
Nailed or screwed, it's all the same.
Bob
« Reply #11 on: July 06, 2011, 03:58:28 PM »
 :yikes:
Offline Nosmo
« Reply #12 on: July 06, 2011, 09:21:27 PM »
No actual FLATS yet as in air loss, but I've had one rear tire on the Connie damaged by a screw (patched) and two rears on the Wee damaged, one by a nail in the sidewall (replaced) and one by a glass sliver in the tread (patched, road several thousand miles and both tires replaced just last Sunday).  No fronts damaged, yet.
« Reply #13 on: July 07, 2011, 04:34:59 AM »
My rear has been nailed, screwed and penetrated far too many times!  :yikes:
I had one on the car and when they swapped out the tyre they handed me the item they found in the tyre.
It was one of those square steel bars that joins door handles together. About 3" long and must be ½" square.
It was a big hole in the tyre and it did go down awful fast.
The problem is that the front tyre rolls over the screw/nail and stands it up.
If yer unlucky the rear then rolls onto it whilst it's still upright and it penetrates.
The same 4:1 ratio applies to cars too.
Offline S.Ga.Rider
« Reply #14 on: July 07, 2011, 05:29:41 AM »
I have had it in the rear twice. I plugged the first tire and used it for several thousand more miles. I replaced the tire and rode to work, about 35 miles, and had a nail in the new tire. I was pissed. lol I took that back to the dealer and had a plug/patch installed because of a track day I had coming up.
I asked the mechanic at the dealer about this when I was getting rotors installed a few months ago and he told me he hasnt patched a front tire in over 10 years, it always happens in the rear.
Offline mlf73
« Reply #15 on: July 07, 2011, 06:24:07 AM »
I've had to plug a rear tire a couple times but never had a tire go flat.  I don't recall ever picking up anything in a front tire.
Offline JetJock
« Reply #16 on: July 07, 2011, 07:24:11 AM »
You need an entry (at the huge risk of jinxing myself) for "Neither. No flats."
[Uhhhh . . . about that jinx thing. This is actually Capt'n Bob posting using JetJock's avatar. Deliver tire karma accordingly.  8)]
Oh, there it is. Nevah mind.
« Reply #17 on: July 07, 2011, 07:43:04 AM »
I had a front tyre blowout at about 80Mph on a German Autobahn riding a Honda CX650Turbo.
Not the best handling bike at the best of times.
I didn't come off the bike which is a f****ing miracle on it's own.  :yikes: :hail: :hail: :hail: :hail: :hail:
The tyre came almost completely off the rim and the front Comstar was trashed.
The tyre wasn't punctured so far as we could tell (me and the recovery driver) so we assumed that it may have been a crack in the rim or else a defective tyre.
Offline mjrfd99
« Reply #18 on: July 07, 2011, 08:49:20 AM »
Try tequlia  ;D   worked for me :thumbs:
Offline Tom J.
« Reply #19 on: July 07, 2011, 03:48:37 PM »
Awe geez, I just realized this was a thread about flat tires and not ..... something entirely different....    sorry!    ;)
I wish more threads had these 'Connie-tations' to them-  It's just good entertainment-
'98 Yamaha VMax
'84 Honda V65 Magna
