Author Topic: Drive Shaft  (Read 1848 times)
Offline Mr. Green Genes
Drive Shaft
« on: March 29, 2018, 07:45:24 PM »
Has anyone come up with a U-Joint rebuild that works?
I just became aware that Kawasaki no longer has new drive shafts in the parts supply line.
Offline Mettler1
Re: Drive Shaft
« Reply #1 on: March 30, 2018, 09:39:06 AM »
Re: Drive Shaft
« Reply #2 on: March 31, 2018, 04:36:57 PM »
NOPE.
no "replacement" sized joints are available, for either the C14 or C10, did all the legwork many years ago, when the first C14 shaft issues appeared.
only option is a new shaft, or one from a boneyard/ebay... but there are a lot of them out there...
https://www.ebay.com/p/Drive-Shaft-Kawasaki-Zg1000-Concours-94-06-OEM-ZG-1000/1022061745?iid=173105085790
and still new shaft assemblies, you have to look a bit...
https://www.partzilla.com/product/kawasaki/39158-1059?gclid=EAIaIQobChMIlY_sgdGX2gIVgrXACh3_mgBTEAAYASAAEgLV6fD_BwE
or try RonAyers...
https://www.ronayers.com/oemparts/partsearch/kawasaki
https://www.kawasakipartshouse.com/oemparts/a/kaw/50a69949f870021678c64072/drive-shaft-final-gear
39158-1059
$350.....
Offline Mettler1
Re: Drive Shaft
« Reply #3 on: March 31, 2018, 11:27:03 PM »
  Kind of curious? Mine has 115,000 on it and still works fine.
