Author Topic: Rear Drive Inspection Tool (C14)  (Read 18792 times)
Offline CrashKLRtoConnie
« on: July 02, 2011, 09:28:43 AM »
Kawasaki Vulcan Inspection Plug Tool K56019-063  (K56019-063 INSPECTION SCREW TOOL)
Works great on the 2008. Does not mar the inspection plug.
« Last Edit: July 02, 2011, 11:40:07 AM by CrashKLRtoConnie »
2008 C14 GTR1400 AKA "Connie"
Offline Caffeinated
Re: Rear Drive Inspection Tool (C14)
« Reply #1 on: July 12, 2011, 06:48:36 AM »
Soo, how do you torque the filler cap with that?
2012 Black Concours 1400
« Reply #2 on: July 12, 2011, 09:59:57 AM »
By feel with an practiced hand. When I used it, bottomed threads then about 1/16 turn.
Offline monk50
« Reply #3 on: December 05, 2011, 04:29:35 PM »
I made a tool by getting a washer with correct thickness (Lowes), then ground the washer to just fit the opening.
To acquire the torque necessary to loosen, I inserted a large screw driver into the hole and bingo it worked.
Initially tho the cap was so tight that it bent a very large metal washer.  This tool can be easily carried and very inexpensive.
08 concours.
Monk50
