Author Topic: GTR giving me a hard time backfiring and stuttering  (Read 21981 times)
Offline mitcheman
  • Country: nl
Re: GTR giving me a hard time backfiring and stuttering
« Reply #20 on: July 10, 2015, 03:44:47 PM »
Hi,
In dont think i'm gonna meet you guys in Breda. Bit of a long drive. Thnx for the help anyways :-D
« Reply #21 on: July 10, 2015, 05:04:50 PM »
The needle guide is what Steve and MOB thought could be the problem.
PS. found an easy way to pull the carbs. In a nutshell:  open up airbox, pull the airboots back and you can take the carb out no problem.
I don't think anyone here has ever mentioned that. Sounds like a good idea to try when I next pull my carbs.
PS: Are you going to meet us in Breda NL?
my hands don't fit in the airbox.....
oh, on a lighter note.... isn't it amazing how Steve and I could diagnose perfectly what was wrong, right from the get go..... without even seeing the carbs.....????
and you guys just have to wonder how we know these things..... ??? 8). heheheh I only posted the cause twice before it was "discovered"... :'(
« Reply #22 on: July 10, 2015, 07:01:50 PM »
Trying to be Rodney Dangerfield?
« Reply #23 on: July 10, 2015, 08:54:47 PM »
did not get the anolgy, but I'll add...
"my wife jsut told me the car is in the dining room.... I asked wtf, and how did this happen..... her reply was I just took a left turn in the kitchen...."
I can't get no respect.... around here... ya know?
https://youtu.be/Iwu-6GxBHN4
Offline Nosmo
« Reply #24 on: July 10, 2015, 11:50:41 PM »
"PS. found an easy way to pull the carbs. In a nutshell:  open up airbox, pull the airboots back and you can take the carb out no problem."
My hands barely fit in the airbox, but that's how I've always done it.
Offline mitcheman
  • Country: nl
« Reply #25 on: July 19, 2015, 08:32:12 AM »
got my hopes up to soon...
when constant at 3000 4000 rpm she keeps coughing down the number 4 pipe.. sparks 1 2 3 are white ish and number 4 black ish.
carb 4 has been completed with missing parts but still i'm having issues there..
See the pic. spark 1 is white number 4 is black.
what am i doing wrong?
Offline qman
    • Autobahn Motors
« Reply #26 on: July 20, 2015, 09:35:43 AM »
You may also have a spark issue. pull the wire and take the spark plug connector off to check for corrosion, sometimes you can cut a 1/4 inch off the wire so that it has clean copper. Pull the wire off the coil and check the resistance of the wire. Should be around 5k ohms I believe with the connector on.
Offline mitcheman
  • Country: nl
« Reply #27 on: July 25, 2015, 11:23:20 AM »
Well I checked the leads, spark caps and plugs. Number 4 lead was lose in the cap. cut it and rescrewed the cap on. Now I got no problems until 5000. When in neutral and I hit 5000 rpm the reight pipe starts shooting again in the pipe.
Could it be that number is getting not enough fuel?
Offline mitcheman
  • Country: nl
« Reply #28 on: July 26, 2015, 05:26:34 AM »
Okay little update.
Just switched the coils l to r and r to l. And I replaced the number 4 spark. Bangs down the pipe at 5000 rpm looks solved. Gonna test ride it and gonna come back to you.
Offline Brad Baerwald
« Reply #29 on: July 26, 2015, 07:44:42 AM »
Mitcheman,  These guys are awesome!  I'm sure that together you guys will get that 4th cylinder work'n right!   They helped me...I was convinced I had both cams timed right and they saw in a photo I sent that I was using the wrong timing mark on the intake cam!
I miss NL,  I lived there 2 different times in my life.  1st time in Den Hauge  and the 2nd time in Den Dolder (if I remember corectly ha ha)  My dad worked for NATO the first time I was there (1971-1974)  I was at the airbase (1985 -88)
I'm just doing the best I can, with the little bit I got!
Offline mitcheman
  • Country: nl
« Reply #30 on: July 26, 2015, 09:17:52 AM »
So I think she's good now.
This is my tune up: https://youtu.be/2nzG1GDHpB8
the drop is from me turning on the radiator fan.
Ps. Don't mind the noise...need a new (after market) exhaust.
« Reply #31 on: July 26, 2015, 10:09:06 AM »
sounds like a GTR is running....woo hooo....
Offline Tzigane
  • Country: nl
    • Photography
« Reply #32 on: August 02, 2015, 11:41:51 AM »
Yay!
Photography : www.masque-obscura.nl
