Author Topic: shinko 777 rear tire not tracking smoothly  (Read 5109 times)
Offline rrman1
  • rode 75 z1 900 100k+ miles. love this 2001 C10
    • jim
« on: May 18, 2015, 12:07:28 PM »
01 1000 concours shinko 777 rear tire w balance beads in it not tracking smoothly at all like dunlop did on my last 01 concours  1000.  tire is size manual recommends. 41 psi. will  try lower psi. adjusted aftermarket shock no help. just started on this issue.  just bought this bike. has aftermarket front springs also.  this rear shock not air adjustable.  feels like r tire has very slight bounce to it.  last bike was rock solid smooth in rear.  thanks for any help.  may try swapping rear wheels w old bike. that should tell me alot.    have heard this tire may be problem.
the only thing that counts is faith expressing itself in love
Re: shinko 777 rear tire not tracking smoothly
« Reply #1 on: May 18, 2015, 12:24:49 PM »
You might suck the bbs out and have the tire balanced.
Offline DC Concours
  • 2001 Concours, ~35K miles
« Reply #2 on: May 18, 2015, 01:47:48 PM »
yup. what he said.
remove those beads and re-balance the old fashioned way.
beads, they didn't work worth sh!t for me.
shinko makes great budget tires. I have the same tire on my 2001 and works like a charm. may be a bad tire; but take those sh!tty beads out first and see.
Offline rrman1
    • jim
« Reply #3 on: May 18, 2015, 02:23:30 PM »
thanks. will do.
Offline rrman1
    • jim
« Reply #4 on: May 18, 2015, 03:29:49 PM »
what is best way to remove beads exactly?
« Reply #5 on: May 18, 2015, 03:51:39 PM »
I'd break the bead and use a shop vac.
Offline Summit670
« Reply #6 on: May 18, 2015, 06:07:44 PM »
A lot of people love the beads and swear they work.  I have never tried them.  I'd be surprised if they are causing handling issues though.
I would make sure the wheel bearings are ok and the swingarm bearings.  The shock linkage bearings might cause some issues but I would think only on bumps.
Arctic Cat M8 163 rules
Offline Steve in Sunny Fla
    • Shoodaben Engineering
« Reply #7 on: May 19, 2015, 06:33:12 AM »
Beads don't work. i experimented with them, not just running them but also running / removing / static balance on the same tire etc, and came to that conclusion. It would be nice if they did... but they don't.  Steve
enim57
« Reply #8 on: May 19, 2015, 08:40:36 PM »
Yep the beads can't work but it's very hard to convince some people even with science, physics, and facts. Read the 6 page discussion (so far) linked: http://drriders.com/topic7007.html
Regards, Russell
Offline rrman1
    • jim
« Reply #9 on: May 20, 2015, 02:23:43 AM »
thanks for all the help. this site rocks.
« Reply #10 on: May 20, 2015, 03:48:32 AM »
Not saying the beads are definitely the problem but more to give you a baseline where to start. You still could have a bad tire or some other problem.
Offline timsatx
« Reply #11 on: May 20, 2015, 07:19:23 AM »
I hope I don't have the problem with this Shinko that I did with the last one. I don't even remember what it was but they discontinued that model. I had tread separation.
