Author Topic: electrical gremlin  (Read 3057 times)
Offline yoman
electrical gremlin
« on: September 23, 2014, 06:57:17 PM »
Gauges, Tach, neutral light, all quit working. Both turn signal indicators both come on with high beams but the high beam indicator does not!
J- Box???????
Thanks, Tom
2002 Semi-naked Connie
Re: electrical gremlin
« Reply #1 on: September 23, 2014, 07:34:19 PM »
did you spray down the bike with a hose, directed at the left grip switch pod?
I think you should start at the major front harness plugs under the front left side fairing pocket, unplug and re-plug them all. Bad connections. Then move on to the J box plug, do the unplug/replug thing. and follow up with whacking the Jbox stoutly with the bike running. Gauges, Tach, neutral light, all quit working sounds like fuse issue.
I thinking the grip pod is the offender, it houses all the connections that would make signals and highbeam issue.
Offline yoman
« Reply #2 on: September 24, 2014, 05:20:42 PM »
okay sorry for forgetting the important stuff, its a 2002 with 63000 miles. oil pressure, neutral, highbeam indicator don't work. tach, fuel gauge and temp gauge are inoperative. turn signal indicators work but come on with highbeams. Tail, brake lights and horn all work normally. four way flashers work correctly also.
Thanks for all of the advice, trying to whittle this down.
Offline tweeter55
  • Ride Hard...Ride Safe
« Reply #3 on: September 24, 2014, 07:35:38 PM »
Sounds like a bad ground in the system if it's feeding through some lamps when they shouldn't be lit.
Offline yoman
« Reply #4 on: September 27, 2014, 11:05:34 AM »
Found a poor connection up  in the fairing. time for some electrical contact cleaner and dielectric grease!
Offline tweeter55
« Reply #5 on: September 27, 2014, 01:21:08 PM »
 :banana :banana :banana :banana :banana :banana :banana :banana
Did I ever mention how much I love this dancing banana?
