Author Topic: GP Suspension Forum Group Buy - Forks, Shock, Penske, Ohlins & More  (Read 11445 times)
Offline gpsuspension
  • The Cutting Edge In Motorcycle Suspension!
    • GP Suspension
GP SUSPENSION FORUM GROUP BUY
TWO WEEK BUY IN ONLY: December 18th, 2013 - January 1st, 2014
Buy now, service when you’re ready
WHY CHOOSE GP SUSPENSION?
Custom engineered suspension for each riders needs and technical support long after the installation, that is GP Suspension's goal. We understand that all riders don't fit in one little box, so we customize each order to make sure that the rider's end result is a bike that handles perfectly, just for them. GP Suspension is committed to providing superior motorcycle suspension products and unsurpassed customer service. All products are inspected and assembled in-house to ensure consistent quality and fast delivery. All GP Suspension products are rigorously tested at the racetrack by local racers and top national motorcycle road race teams, and are constantly refined to ensure that performance exceeds all expectations. GP Suspension currently offers a line of fork valving kits, shock valving kits, compression needles, fork and shocks springs, suspension tools and the very popular 25mm fork cartridge kit.
:goodpost:Here is a link to WMRRA President Tim O'Mahony, tim61, who had a  GP Suspension fork upgrade and Penske shock installed earlier this year: http://www.zggtr.org/index.php?topic=12054
ORDER HERE
http://events.constantcontact.com/register/event?llr=kku45aeab&oeidk=a07e8oygjkx8bbc8991
WHAT IS OFFERED IN THIS GROUP BUY:
FORK UPGRADE:
Complete and total overhaul and upgrade of your 43mm KYB forks. GP Suspension Compression Kits, Rebound kits and Fork Springs. This will TRANSFORM the front end of your Concors to a staggering degree. Riding the bike after this upgrade is something that has to be experienced to appreciate. This is *THE* crown jewel of this Group Buy! For the do-it-yourself folks, you can obtain new GP Suspension fork springs at killer prices.
ACTUAL KIT MAY BE DIFFERENT THAN PICTURE
FORK SERVICE:
Already have an upgraded front end, forks service only is also included in this group buy.
NEW SHOCK:
Penske or Ohlins, your choice. Shocks will be fitted with a custom spring specific to your size and riding style. You may also purchase a custom shock spring separately if you already have an aftermarket shock.
SHOCK SERVICE:
Whether you have an Ohlins, Penske or Wilbers. Those of you with a Wilbers should absolutely consider letting GP Suspension upgrade your under-sprung or otherwise spent Wilbers. Overhaul includes new suspension fluid, nitrogen re-charge, new quad seals, etc. They will measure your spring rate to ensure it is in the correct range for your riding weight.
FORK SERVICE
Labor $178
Oil $24
Fork Seals $24
Chemicals/waste $10
*Dust Seals, Bushings Additional
________________________________________
Retail $236 - Group Buy (Save $50) $186
GP SUSPENSION FORK UPGRADE PRODUCTS:
20mm Fork Re-Valve Kit – Retail $189, Group Buy $149 (Save $40)
PENSKE SHOCK SERVICE:
Shock Labor $178
Shock Oil $12
Nitrogen $10
New O-Ring Seal $10
Chemical/waste $10
Retail $222 - Group Buy (Save $50) $172
OHLINS/WILBERS SHOCK SERVICE:
Shock Labor $178
Shock Oil $12
Nitrogen $10
New Quad Seal $10
New Dust Seal $10
Chemical/waste $10
Retail $230 - Group Buy (Save $50) $180
FORKS SPRINGS / SHOCK SPRINGS:
Shock Spring Retail $115 - Group Buy $85 (Save $30)
Fork Springs Retail $110 - Group Buy: $80 (Save $30)
SHOCK UPGRADES:
All shocks will be custom setup for your riding style and weight
ACTUAL SHOCK MAY BE DIFFERENT THAN PICTURE
Penske 8975 Double Adjustable - In-line Reservoir (2008-2014) - $870 Retail, Group Buy: $770 (Save $100)
Penske 8983 Double Adjustable - Remote Reservoir (2008-2014) - $925 Retail, Group Buy: $825 (Save $100)
Ohlins YA709 Double Adjustable W/ Hydraulic Pre-load Adjuster (2008-2009) - Retail $1338, Group Buy $1205 (Save $133)
Ohlins YA109 W/ Hydraulic Pre-load Adjuster (2010-2012) - Retail $1338, Group Buy $1205 (Save $133)
*Note: Freight is not included, and there will be a freight cost in and out on all shocks
ORDER HERE
Mix and Match any of these services, but remember, this group buy is for,
  TWO WEEKS ONLY: December 18th, 2013 - January 1st, 2014............. so don't delay ordering, folks.
« Last Edit: December 18, 2013, 09:51:12 PM by gpsuspension »
GP Suspension
1425 22nd ST NW Ste F
Auburn WA 98001
info@gpsuspension.com or 253-397-4474
    • GP Suspension
Re: GP Suspension Forum Group Buy - Forks, Shock, Penske, Ohlins & More
« Reply #1 on: December 19, 2013, 04:54:18 PM »
Introductions are in place, http://www.zggtr.org/index.php?topic=16046.0
 :feedback:
GP Suspension
Auburn WA 98001
