Author Topic: Bringing back an 08 C14  (Read 6657 times)
Offline Alex_V
« on: November 22, 2013, 04:50:12 PM »
So, I am in process of re-building a crashed C14. Few things that I would like to find used vs paying new parts prices. Anyone is parting out a C14 that can help me out? This is what I need:
LOCK-ASSY, SIDE BAG, LH   27016-5355 (latch part broken)
WINDSHIELD-ASSY   55036-0005 (whole assembly was replaced by a home made aluminum bracket)
BRACKET,COWLING   11055-1804 (aluminum piece that bolts to headstock)
STAY,COWLING,RH CNUS   35063-0675 (steel bracket on right hand side, this I may be able to re-use)
COVER,INNER,RH   14092-0114 (black plastic cover on top of side fairing)
COVER-ASSY   16146-0081 (These are glove box part numbers)
COVER-ASSY   16146-0084 (Same)
DISC,FR,HOUSING BLACK+DISC SIL   41080-0102-5C (Both front disc are warped, can I use discs from other models?)
COVER,METER   14091-0890 (outside dash cover, mine has scratches not a must)
BRACKET,METER COVER,LH   11054-1786 (little bracket that connects to left air duct)
KNOB,AIMING   92077-0015 (headlight adjustment knob has some scratches, not a must)
COWLING,LWR,RH,BLACK   55028-0200-18T (black right side lower fairing)
GASKET,HEAD COVER   (I got to fix the cover leak, this is new part buy)
SENSOR,TPMS 315MHZ   (Front was not picking up, but that could of been due to a cut wire in the harness)
HOLDER-FORK UNDER   44037-0061 (lower triples, do any other models fit?)
Thanks
Alex
Re: Bringing back an 08 C14
« Reply #1 on: November 23, 2013, 08:23:45 AM »
For the plastics you're needing are you only looking for 08 silverdammit color?
Offline Gsun
« Reply #2 on: November 23, 2013, 11:30:34 AM »
The TPM sensor could be a dead battery. They are replaceable if you mess around enough. Replace both when doing new tires.
« Reply #3 on: November 23, 2013, 12:30:02 PM »
Why Jay, do you know of some plastic in other colors avaialble anywhere? Hmmmmmm?
Offline Alex_V
« Reply #4 on: November 23, 2013, 12:53:50 PM »
Yeah, I am not planning on repainting the bike. So keeping it silver seems a way to go
Thanks for the tip on the battery. Didn't realize they were battery powered.
Lower triples is probably the most needed item right now. 100 bucks on unknown quality ebay listings, or $420 new from discounted sites.
« Reply #5 on: November 23, 2013, 01:20:04 PM »
I don't see forks on your list.
« Reply #6 on: November 23, 2013, 01:36:23 PM »
or knives...
« Reply #7 on: November 23, 2013, 02:50:42 PM »
....there is no spoon.
Offline Gsun
« Reply #8 on: November 23, 2013, 06:11:55 PM »
Here is a link for pics on replacing the batteries. There is a screw to open them below the spec sticker. You can peel it back or I just cut an X in it to get at the screw.
http://forum.cog-online.org/index.php/topic,37344.0.html
Offline Alex_V
« Reply #9 on: November 24, 2013, 12:12:03 PM »
Good tip, thanks
Forks are good, the way the bike was hit just damaged the triples. Right side is ovaled.
« Reply #10 on: November 24, 2013, 01:02:03 PM »
Good tip, thanks
Interesting. How was the bike hit that the trees could be damaged without trashing the tubes?
« Reply #11 on: November 24, 2013, 01:35:07 PM »
I agree with GP on that...  ???
Offline tweeter55
  • Ride Hard...Ride Safe
« Reply #12 on: November 24, 2013, 04:39:16 PM »
That makes at least three of us.
Offline Alex_V
« Reply #13 on: November 24, 2013, 07:51:12 PM »
Usually I would agree that something has to be up with the forks themselves. My hypothesis here is that point of impact was right at the lower triple. Strongest part of the fork tube is what actually damaged the inside of the triple hole. Triples are not tweaked, just the inside opening is ovaled.
Bottom line, I am not going to ride anything unsafe and will replace all parts that are showing damage, or has potential to fail. My buddy helping with the rebuild is a mechanical engineer and we both agreed that forks survived and can be reused.
« Reply #14 on: November 25, 2013, 04:04:17 AM »
No offense intended, Alex. Just quite unusual. Please keep us informed of your progress.
Offline tweeter55
« Reply #15 on: November 25, 2013, 04:47:56 AM »
 :popcorn:
Offline Alex_V
« Reply #16 on: November 25, 2013, 11:38:50 AM »
Not offended at all. Glad you made me double think what I was doing. Here is a link to the re-build:
http://www.zggtr.org/index.php?topic=15800.0
