Author Topic: 4 inch Bar Risers with 3 inch Pull Back to the Rider  (Read 15501 times)
Offline Kas
« on: November 07, 2013, 06:11:05 PM »
We continue go lower the inventory and are selling;
 4 inch Bar Riser's that bring the grips back to the rider 3 inches.  You can use both the factory hoses and cables with the throttle cable rerouted.  The 4 inch risers can be used with 2008 thru 2013 C-14's.
 3 inch Bar Risers that bring the grips back to the rider 2 1/2 inches. The factory hoses and cables can be used. These will block access to the glove box on 2008-09 C-14's.
 2 inch Bar Risers that bring the grips back to the rider 2 inches. Again these will  block access to the glove box on the 2008-09 models.
All Bar Risers are $325.00 delivered to the lower 48 states.
Both risers are powder coated billeted aluminum and drilled and threaded for Motorcycle Larry's 5/16ths Ram Ball mounts.  All Bar Risers come with all mounting hardware (no black plugs are included).
« Last Edit: November 13, 2013, 04:46:00 PM by Kas »
Offline mvjr1904
Re: Pull back Bar Risers
« Reply #1 on: November 08, 2013, 02:30:29 AM »
Any pictures available?
Maybe an overhead picture to see how much pull back there is vice the stock position
2011 Silver C14 - Fastest
2002 Silver C10 - Fast
Offline Kas
Re: 2-3 inch Pull Back Bar Risers
« Reply #2 on: November 13, 2013, 04:34:14 PM »
Here are some additional photo's of the Bar Risers on a Concours.
Offline Kas
Re: 4 inch Bar Risers with 3 inch Pull Back to the Rider
« Reply #3 on: November 13, 2013, 05:03:21 PM »
These photos show the handle bar location with a 1 3/4 in bar riser and the handle bar locartion with a 4 inch bar riser with a 3 inch pull back to the rider.
The 3 inch pull back relieves the "between the shoulder ache", it lets a tall sit upright taking the weight off his shoulders and allows the not so tall rider to sit back in the seat.
« Reply #4 on: November 13, 2013, 05:08:23 PM »
Did I miss the link to a website?
Offline Kas
« Reply #5 on: November 13, 2013, 05:21:26 PM »
We do not have a web site to order from.
« Reply #6 on: November 13, 2013, 07:31:37 PM »
Kas, Kas, Kas, tut-tut-tut, must I do everything?  (Nice comparison photos by the way.)
Our business information: (All payment should be made out to BMS Inc. we do accept Visa and MasterCard)
BMS Inc
6180 E Commerce Loop
Post Falls, ID. 83854
Phone 877-905-1593
Now before some start to suspect that I'm in key-hoots with you, let me ask some more questions.
Are you guys going out of business?
What happens if say, Gumby orders the 4" risers and can't get his brake lines to fit ('cause for some reason his are shorter than all the rest) and
he wants to return them and get a refund?  Can do? No way? Re-stocking fee?
« Reply #7 on: November 13, 2013, 08:50:21 PM »
I have 2" risers with AST pullbacks and my lines are already tight.  :popcorn:
Offline Kas
« Reply #8 on: November 13, 2013, 09:34:38 PM »
Our bar risers will only work with ABS models. The 4 inch is the max for stock lines and cables. The 3 inch gives you more slack but nearly the same rise but 3 inches of pull back at the handlebar ends.
Our 2 inch risers bring the bar ends back over two inches from stock.
Offline CeeRider
« Reply #9 on: September 27, 2015, 06:55:56 PM »
Kas,
Are these still models available or did they stop making them?
Ride safe.
