Author Topic: Concours Escort Kits  (Read 12931 times)
Offline Kas
« on: October 14, 2013, 01:41:27 PM »
Concours Escort Kits Include:
8 Amber LED lights (1.6 amp draw), Two under mirror, front mounted forward facing and two front mounted side facing LED emergency lights., Two rear pod mounted rear facing and two rear mounted side facing LED emergency lights.  Switch pod with two lighted switches, one for activated front lights, one for activated rear lights.  Electrical harness with one connection to the battery and 15 amp in-line fuse.
Only two small holes need to be drilled for the forward emergency lights and no other modifications are needed for the up-fit of this kit.  The rear pod mounts between the luggage rack and grab rails and weight less than 4 pounds.  Front side panel plastic will need to be removed, but the gas tank does not need to be removed to run the harness.
This kit is available with optional siren/air horn/PA and drop bars.
« Last Edit: October 24, 2013, 10:44:44 AM by Kas »
Re: Concours Escort Kits
« Reply #1 on: October 14, 2013, 02:54:14 PM »
GULP!!!
If I were doing a fair amount of escorts with the Connie these would work out great.
GLWS's.
Offline SMurphy
« Reply #2 on: October 05, 2015, 06:09:53 PM »
im interested. whats the cost? also interested in siren pa kit.
CMA Texas Fast Lane Team
« Reply #3 on: October 06, 2015, 09:58:51 AM »
This is very old stuff (posts) I doubt Kas still sells them and hasn't logged on here since May.
You might try to email him through the forum, but don't get your hopes up.
Offline SMurphy
« Reply #4 on: October 06, 2015, 07:57:41 PM »
Figured
