Author Topic: Accessory Leads In Front Of Bike  (Read 6975 times)
Offline C14-Pilot
  • Riding Pushmountain Road In Arkansas
« on: June 04, 2011, 07:50:22 PM »
Guys,
I found this somewhere on the old  forum before the crash.
Now I am ready to use the accessory leads and now I cannot read remember what I read before.
Looking at the accssory leads at the front of the bike there are 2 bullet connectors.
Which one is the hot wire and which one is the ground?
thanks,
Hwilks
2008 Kawasaki Concours 1400, 2006 Kawasaki Vulcan 900, 2005 Kawasaki Vulcan 750
1980 Yamaha 650 Maxim,1977 Kawasaki KZ 400 Deluxe II,1973 Honda 250 Elsinore
Offline koval68
Re: Accessory Leads In Front Of Bike
« Reply #1 on: June 04, 2011, 09:02:32 PM »
(+) Black
( -) Black/Yellow
- Mahatma Gandhi
« Reply #2 on: June 04, 2011, 10:17:07 PM »
In addition to what Tom said, the (+) lead has a female bullet connector and the (-) lead has a male bullet connector. Both connectors are standard 5/32" (4mm for you metric types) bullet connectors.
(+) Black
( -) Black/Yellow
Bob
« Reply #3 on: June 05, 2011, 05:01:59 AM »
All this is correct. But it never hurts to verify this with a meter anyway. I normally do, just to be on the safe side.
Offline koval68
« Reply #4 on: June 05, 2011, 06:30:05 AM »
After mowing your lawn, do you get down on your knees with a tape measure and a scissors to make sure your lawn height is 2.5 – 3.5 inches ...Just Curious... :rotflmao:
Seriously...Now, Cap'n Bob is right, you should always check if not sure!
- Mahatma Gandhi
Offline leyenda30
« Reply #5 on: June 05, 2011, 08:08:32 AM »
Anyone know the fuse rating for these leads?
05 Honda VTX
07 Husky SM610 sold
« Reply #6 on: June 05, 2011, 08:09:53 AM »
10 amps on '08 and '09 models, 5 amps on 2010 and 2011 models.
« Reply #7 on: June 05, 2011, 08:13:58 AM »
Yeah, especially since Kawasaki wired the entire bike without checking voltages anywhere- the female connectors are hot (+) and the male connectors are ground or zero volts (-). If Kawasaki is going to start wiring their harnesses backwards, well we all might as well just ride Yamahas 'cause it can't get any worse.... (notice how I did not mention the <k-word> anywhere in there but it was implied?)
 :o
Flathead
« Reply #8 on: June 05, 2011, 09:41:14 AM »
And .156" for you decimal types  ;)
Offline Y0ssarian
« Reply #9 on: June 05, 2011, 09:59:50 AM »
 :o
If the (+) lead was a male connector it might contact a ground and blow a fuse. It makes sense to make the (-) leads male.
« Reply #10 on: June 05, 2011, 10:48:31 AM »
Yup....
Offline koval68
« Reply #11 on: June 05, 2011, 11:03:12 AM »
 :o
Shh! You're gonna wake up the sleeping giant!
- Mahatma Gandhi
