Author Topic: Headlight out NEED SOME HELP  (Read 13542 times)
« on: June 10, 2013, 04:03:47 PM »
I had a headlight go out on my way over to Idaho last week. I have the AandR HID's. I pulled some plastic off and everything looked good, fuses, wiring, so I figured it was the bulb. I called AandR last week and ordered a couple new bulbs. Kudos for the fast delivery, they showed up in the mail today.
Plug in the new bulb and still NO WORK  :(
AandR is closed today so I figured I could look to you guys for some suggestions on what to do next.
Thanks,
Re: Headlight out NEED SOME HELP
« Reply #1 on: June 10, 2013, 04:05:48 PM »
That would only leave the ballast wouldn't it?
« Reply #2 on: June 10, 2013, 04:22:48 PM »
You may be right. I plugged in the stock bulb and it works fine. I guess I will try the ballast off of the right side.
EDIT:
I plugged my original HID bulb into the other ballast and it works fine.  :)
Now I have to wait for AandR to open tomorrow to have them send me a new ballast, and I have two extra bulbs if mine ever do go bad.
Jay your in luck, if yours go out we have replacements.   :thumbs:
« Last Edit: June 10, 2013, 05:11:18 PM by Gumby »
« Reply #3 on: June 10, 2013, 05:33:11 PM »
Nice!  :) :chugbeer:
« Reply #4 on: June 17, 2013, 08:01:18 PM »
Got a ballast in the mail today plugged it in and lit up my garage  ;D
Put everything back together just in time for the :censored: rain tomorrow.  >:(
I was really hoping somebody would say check the inline fuse to the bulb.... wishful thinking huh?
Thanks for your input g,
