Author Topic: Interchangeable? C-10 generator and 1990 Zx1000 Generator?  (Read 2264 times)
Offline concours_to_go
« on: December 04, 2011, 01:39:03 PM »
I have done a part number cross reference, and they are different, but I'm wondering if it is due to the output. Someone here must know, Are they interchangeable? What is the difference?
TIA,
Jim
NEWBIE...?
I'VE BEEN HERE FOR 10 YEARS
Offline GeeBeav
Re: Interchangeable? C-10 generator and 1990 Zx1000 Generator?
« Reply #1 on: December 04, 2011, 04:03:07 PM »
The ZX-10 alternator will fit, but less wattage.
ZX-11 or ZRX has same output.
« Reply #2 on: December 04, 2011, 04:07:54 PM »
Do you happen to know, How much wattage?
NEWBIE...?
Offline GeeBeav
« Reply #3 on: December 04, 2011, 06:49:46 PM »
No, but based on physical size, I'd say more than the 350 watts of the early Ninjas, less than the 400 of the ZG/ZRX/ZX-11.
Offline Mettler1
« Reply #4 on: December 04, 2011, 08:02:18 PM »
  Here is another possibility. If you can find one!
http://www.delp.net/Concours/Tech/Microfiche/Generator/index.htm
Offline Centex
    • Central Motorcycle Roadracing Association
« Reply #5 on: December 04, 2011, 09:49:12 PM »
Jim, I sent you a PM; make me an offer if you are in need.
Mine is a perfect fit, 100% for sure  ;)
Alan in Central Texas
2004 Connie COG 9476
2001 Ducati M750
« Reply #6 on: December 05, 2011, 04:43:38 AM »
I'm not looking to buy one, just seeking specs.
NEWBIE...?
