Author Topic: Rear brake pad replacement  (Read 2040 times)
Offline George R. Young
  • Moderator
    • Concours 2001 Farkles
« on: August 28, 2011, 12:49:20 PM »
C10, 2001, 66,493 km inside rear pad was worn down to 1mm. Probably the original pads. Straightforward replacement, only spilled a bit of old brake fluid, getting ready for a trip.
There's a rotating disk on the end of the slave piston, anybody know what it's for?
Offline jim snyder
Re: Rear brake pad replacement
« Reply #1 on: August 29, 2011, 10:34:35 AM »
Those are heat isolaters, they keep heat from the pads from transfering to the caliper.
Offline Pfloydgad
« Reply #2 on: August 29, 2011, 01:14:08 PM »
George,
Don't forget to check that rr. hub spline in the rr. wheel. My 01 puked hers at 70k and left me stranded. Your already in there, might as well pop the o-ring and pull it off and give it a good look see.
Oh yea, what Jim said.
Ride safe all, ATGATT please.
Greg
  • Moderator
« Reply #3 on: August 29, 2011, 02:52:03 PM »
I removed the rear caliper without taking off the wheel. But I will soon be putting on a new rear tire, and the splines will be checked, both in the wheel and in the drive shaft.
