Author Topic: C10 - Forks, Upper and right side plastic, RH mirror for 2001  (Read 3862 times)
Offline WillyP
    • Suncook Carpentry
Upper and lower fork tubes, and maybe triple clamps too,for a 2001. Someone correct me if I am wrong but I believe a '99 and up would fit. I would also consider an upgrade front end with a 17" wheel, but I think that would blow my budget. However if you have something for sale let me know.
Upper and right side fairings. I don't care what color, or if it needs minor repair or to be repainted. RH mirror. RH rider and passenger footpeg.
Edit: Forks and triples purchased.
« Last Edit: May 24, 2011, 03:20:01 PM by WillyP »
Offline Jet
  • Dark Side of the Moon
Re: C10 - Forks, Upper and right side plastic, RH mirror for 2001
« Reply #1 on: May 24, 2011, 01:28:31 PM »
I have forks and triple clamp, forks on upper part have a bit of small rust, fork seals need replaced and I have the stock front tire all from a post 94 bike.  I do not have the axle.  Make me an offer and I'll try and get pics of all for you and confirm the year they are coming from.
...and a good time was had by all.
Offline Connito
« Reply #2 on: May 24, 2011, 01:49:31 PM »
I have pretty much everything you need. Where are you located?
"Old enough to know what's right, but young enough not to choose it”
Offline WillyP
    • Suncook Carpentry
« Reply #3 on: May 24, 2011, 03:18:16 PM »
Thanks, just made a purchase of the forks and triples. I am located in Pembroke, NH.
Offline Jet
« Reply #4 on: May 24, 2011, 04:27:50 PM »
Offline Jet
« Reply #5 on: May 24, 2011, 04:30:55 PM »
I believe I have the rh passenger peg.
Offline WillyP
    • Suncook Carpentry
« Reply #6 on: May 24, 2011, 04:58:27 PM »
Connito says he has everything I need and he's just an hour or two away, so I'll probably pick everything up from him. If there is something I need he does not have or we can't come to terms, I'll post here with what I need.
Thanks for your quick reply!  :)
Offline Connito
« Reply #7 on: May 24, 2011, 07:43:02 PM »
Well, I had the triple tree and the forks also, but anyway. I have everything else with the exception of the front peg. You are welcome to come over my place, or I can meet you half way. However, I would suggest you come over as I have plenty of parts to choose from.
Email me if you are interested.
Pete
« Last Edit: May 24, 2011, 08:19:17 PM by Connito »
