Author Topic: High speed wobble  (Read 14790 times)
Offline Coomers
High speed wobble
« on: July 24, 2012, 06:43:52 AM »
I have an 08 Conny with 22,000 miles on her. I seemed to have created a high speed wobble at about 120 – 130 MPH. At first I thought it was because my PR 2’s were worn but even with my new PR3’s I have the same wobble. I assuming it may be the steering head bearing but would like the forms opinion. And if it is the head bearings do I need to change the bearings or can I get away with just torqueing them.
Thanks,
Offline McJunkie
Re: High speed wobble
« Reply #1 on: July 24, 2012, 07:02:34 AM »
If you haven't already, I believe at 15000 you are supposed to grease the bearing then re-torque them. Of course the simple solution is not to go 120-130 mph.
Offline Bourne2Ride
« Reply #2 on: July 24, 2012, 08:23:00 AM »
Hey Doc, it hurts when I do this...  ::)
- Heroes
« Reply #3 on: July 24, 2012, 10:12:52 AM »
Offline philipintexas
    • Phils Farkels
« Reply #4 on: July 24, 2012, 10:17:37 AM »
When you do the job, you'll need a special tool to fit the bearing adj. ring. I think they're available from "Motorcycle Larry".
Offline Coomers
« Reply #5 on: July 24, 2012, 10:38:00 AM »
Thanks Guys,
Offline Coomers
« Reply #6 on: July 24, 2012, 10:50:59 AM »
Motorcycle Larry doesn't have it listed on his website does anyone know where else I can get one?
Offline bigdogbites
« Reply #7 on: July 24, 2012, 01:19:44 PM »
I have one that I bought a while back and never used --let me know if your interested?
« Reply #8 on: July 24, 2012, 02:59:00 PM »
Send an email to: ehcycledude@yahoo.com
He makes these shockets. Not sure if he has any available at the moment, so your best bet may be to get with bigsogbites on the one that he has.
Offline wally_games
« Reply #9 on: July 24, 2012, 08:52:20 PM »
What's the easiest way to check to see if it's loose?
Offline texrider
« Reply #10 on: July 24, 2012, 10:05:01 PM »
With the bike on the center stand, support the frame to hold the front wheel off the ground. Grap the lower fork legs and see if you can detect any bearing play, while pushing/pulling the fork front to rear.
Also, check how easily the wheel falls into full lock left and right. Normally, there is slight resistance.
My lazy way to snug them? Reach in from the side with a long punch, and use a hammer on it to drive the notched nut tighter.
2014 Valkyrie
Offline Irish-14
« Reply #11 on: July 24, 2012, 10:33:27 PM »
I almost sold my 2011 because of a high speed wobble that I got after I hit a softball sized rock and blew both tires and rims. The wobble wasn't there before, and now it wouldn't go away, happened at about 130mph plus. I finally figured out that it was the PR2's that I had put on after the crash, they were much "thinner" than the B-023's that came with the bike. After going back to the B-023's, the bike is dialed in at 150mph and I am glad to say I'm keeping my girl (Connie.) If I didn't want to ride at those speeds, I would've bought a bike that didn't share the same engine as the zx-14!
« Reply #12 on: July 25, 2012, 12:04:57 AM »
another plus is driving to work in the morning and ending up in the front at some traffic light, on a two lane road, and a Maseratti GT on the other lane wanting to drag. I usually don't bother but the guy in the car was begging for it...  ;D
For everything else, Yamaha makes a wonderful YBR 125 with which these guys went around the world.
« Reply #13 on: July 25, 2012, 05:07:49 AM »
That's crazy talk right there.
Offline Coomers
« Reply #14 on: July 25, 2012, 06:18:23 AM »
PM Sent.
Offline rtarp1
« Reply #15 on: July 25, 2012, 08:33:51 AM »
I love all the old timers or wimps who never use the performance the bike was built for.   you know who they are , they are always complaining or  trying to figure out how to get better gas mileage or getting 10k per set of tires.      boriiinnggg .    :o
« Reply #16 on: July 25, 2012, 10:23:50 AM »
 :goodpost:
Offline wally_games
« Reply #17 on: July 25, 2012, 11:30:56 AM »
I am a semi-old timer, I guess, because I like the speed, handling, etc. of the Connie, but I also want a bunch of miles out of the tires, especially when forced into straight-line highway travel. The gas mileage doesn't matter that much, because I can still go farther between fill-ups than most of my riding buddies.
I can honestly say that the speedo on my Connie will register 162 mph (yes, I know from experience that is really ONLY about 154-156), although I really don't recommend trying that.  ;)
« Reply #18 on: July 25, 2012, 11:34:45 AM »
I love all the old timers.....
 :-*  I love you too, but don't tell the wife.  ;) 8)
« Reply #19 on: July 25, 2012, 11:37:24 AM »
Ok you two, break it up or get a room.   :-*
