Crappy pictures but you get the idea.
"Commuter Mode" W/15" shield cut down and Painted (By "F-106).
The "Goodie List".
ZRX 6 Pot Calipers up front.
Spiegel S/S "Smoke" lines front, rear and clutch.
"Murph's" Fork brace with Fork Protectors.
Coil Sticks.
Block Off Plates.
Piazzo "Knock-Off levers (Black W/Red adjusters).
Volt meter, air temp gauge, garage door opener, "Powerlet" socket with "On/Off" switch on dash.
Throttlemisters, Heavy ones.
Grip puppies,
Cee Balieys 24 1/2 touring shield (W/Vent), a 13" and a 15" painted "Summer" shields
Driving light mounting brackets up front.
Highway bars.
Modified Luggage Rack with the Large JCW Top Case (The top case has two strips of LED brake lights under the red lens).
LED running lights on the luggage rack and lower rear fender.
Greg couch's ZRX 1100 rear brake link.
45 degree air valves in the wheels
Michelin Pilot GT's front and rear.....(about 1/2 worn..9K miles on'em).
New Maintenance free battery installed this spring.
AMSOIL Full Synthetic 10W40 and a K&N-401 oil filter.
Rear Diff gets Lucas Full Synthetic gear oil SAE 90.
As of last night she has 15,568 miles on her as I was pulling in the garage.
